I finally got around to starting this job on the weekend. I'm pretty slow, so I only got the drivers side disassembled, but it's mostly going well. I ran into two problems:
- The top ball joint popped out no problem, but the bottom is stuck. I have a couple of ideas to try for that one.
- The top ball joint is out of the knuckle, but it's stuck in the control arm. My impact wasn't doing anything to it, and my longest breaker bar was starting to flex like it was going to break. I could get a better bar, but I doubt that I'd have many other chances to use it and it might not even work for this job. I really didn't want to have to replace the control arm since it's so new, but that might be the safest course of action. I'm trying to decide between:
- MOOG - RK620369 According to MOOG RK is 'value-driven' whereas 'K' is 'problem solver'. I've heard lots of horror stories about MOOG, but so far all of the parts that I've got were manufactured in the US or in Turkey which is encouraging.
- MEVOTECH - CMS25135
- Buy the MOOG or Mevotech control arms and screw out the ball joint that comes with it and install the K7082 that I already have. I figure I should be able to change the joint if it's brand new and off the vehicle.
- Doorman 520-317 The upside to this part is it's what's already on the van and I could just replace the drivers side where the joint failed. The downside, is it's the part that failed after just 12 years!
When you say it is "stuck in the arm" and can't get out with an impact wrench or breaker bar, I assume you are trying to unscrew the joint from the arm? If so, I am not surprised and screw in joints do that pretty often. But you said earlier that the balljoint you have is a press in joint so are you sure it is not a press in joint in the arm? You would never be able to turn a press in joint.
Does it have bolt in, with 4 bolts, to hold the joint in? Many aftermarket do that instead of press or screw in because the tolerancing of parts is much easier to do for all different variations they have to make.
If it truly is a screw in joint, you may be able to get it apart by using a torch, but it will be a smoky adventure.
Remove the boot and clean all the grease out of the joint that you can get to. Take out the grease fitting if it has one and clean the area by squirting solvent into the joint. You may be able to puncture the sheet metal ball retainer and pry it out which will let you remove the ball and all the grease, which is best.
Using a oxy acetylene torch is best but a MAP gas handheld torch usually is enough. Do the first heating outside as it will still smoke at least some. You can then move inside to do it for real and hopefully well restrained in a solid vice or other way.
Put some penetrating oil on it and let it sit for a least a couple of hours. I like Kroil the best and PB Blaster next.
Heat only the arm, not the balljoint itself around the threaded area but not as far as it starting to turn red. Rap it with a hammer and flat end punch around the threaded area. Reheat and get on it with the breaker bar and pipe if necessary. If you have a helper to pound on the arm at the same time it may help. You probably won't break your breaker bar on the bar, but might break the pivot pin on it or the socket itself, especially if it is a 12 point.
If it doesn't help, take it back outside and get it hot again, but not as hot as before to be safe, and CAREFULLY squirt penetrating oil on the threaded area of the joint. It is best to heat to relatively lower temp first until you find out where the oil will running in the joint well and not flaming. Don't use aerosol penetrating oil because the gas can be very combustible. You probably will get so flame from the oil so be in a spot that won't burn (not sitting on cardboard or wood).
Some will not come apart without tearing out all the threads that have been weakened by all the rust and stress on them and then you have to get new arms.
Bolt in joints are great, press in are tough and need special pressing tools and probably a 20 ton press, and screw ins are the really terrible ones to deal with. Truck shops will use a 3/4" drive impact wrench on them, I think, and those impacts are huge and can have 2000# or more impact torque.
