markopolo-ClassB
NEC 2008:Table 250.122
Minimum Size Equipment Grounding Conductors for Grounding Raceway and Equipment
That would not seem to apply to how you're using that run of 6 AWG.
In an RV you'll typically see the following over current protection:
15A with 14 AWG
20A with 12 AWG
30A with 10 AWG
40A with 8 AWG
50A with 6 AWG
Etc.
That makes me all the more curious about the full intended use of the original line with the 150A breaker on it. I don't see it in the before schematic. Was it / is it used to boost an LFP module for example? What size AWG wire was 150A breaker protecting originally?
What are the triggers to take the C+ & D+ terminals offline? Is it low temperature, high voltage, high temperature, low voltage for for both but at different setpoints?
