- Joined
- Jul 24, 2013
- Posts
- 5,438
What are the plusses?
In any case, while I am aware that you justifiably have major issues with EHGNA and Jim Hammill, how was the 6 year warranty fictional prior to the point where EHGNA went kaput?
A warranty must bank 5% to 10% of the BOM cost compounded for each year of warranty passed year-one. The precent is chosen based on the MTBF of the components. That formula falls apart if the warranty extends beyond any component's MTBF "bathtub", which is the case for the relays and LiFePo4 cells.
6-years was also doomed since the warranty fund calculation assumes thorough testing already rang out the latent design defects. Clearly testing was left to the customers.
That goes without saying. They went under. Could be it was just a pyramid scheme gone awry by EHGNA management too soon before Thor finalized the deal.All true except in this case the warranty was simply a marketing tool unrelated to actual future costs for warranty coverage. It is pretty clear that EHGNA was not doing business in a financially sound manner isn’t it?
It will be $7,000 dollars to replace both my modules. They can't replace one because module Rev H isn't compatible with Rev G.
Ok, here I go.
Replacing my EcoTrek with a custom build. Reusing the same cells and battery box for a drop in replacement.
Attached is my super simple schematic. No relays, no battery heaters, virtually no parasitic draw.
Diagnostics via Bluetooth, and parameters programmable via Bluetooth, so I'll have tons of info to post here on the forum.
Expected to complete the project in 4 weeks.
Ok, here I go.
How much is the Smart BMS costing you? I just bought a REC Active BMS for my setup, which so far has seemed pretty decent and well built. Though I do have some parasitic draw from the relays (About 100mA with just one, so not too terrible.) I need to add up what I spent on the REC, but I believe it was about 600CAD shipped, and with customs fees/duty
It was $326 USD shipped from Germany. Google "123 smart BMS"
If you're up for it, get rid of those relays and go with FETs. 100mA for a relay, ~1mA for a FET, plus they will last a lot longer and are much more reliable. I'm using the Victron BP-100 and BP-220 which will take 600 amps peak.
My goal is to go all solid state if possible.
When both terminals are connected then everything is connected in parallel, the loads, the chargers, and the AGM. The inverter has been moved around, it seemed to be on the discharge side originally but has been moved to the charge side recently. Since it is both a load when it is inverting and a charger on shore power neither location is ideal.
When the charger is connected to the charge port, if the port senses a fully charged battery condition, it opens the port. Got that. The charger sees no load and consequently quits charging. But isn't the inverter/charger still powered up and why would the 120V pass thru path to the AC panel be inhibited? Even powered down, isn't the transfer relay normally closed?
The transfer relay only activates when the inverter is on. When the inverter is off it does nothing, no pass through, no battery charging, no inverting, nothing operates.
Well, the charger will see the AGM battery and charge it even if all the Ecotreks get fully charged and all disconnect the cells from the charge ports.
As long as the inverter is on and connected to shore power then the transfer relay will activate and pass the shore power through to the van.
When inverter was on the load side there was the issue that when all the Ecotreks were disconnected from the load port there was nothing connected to the shore charger and the 12v output was very unstable. Transfer relay was still sending shore power to the van.
I have to be continually reminded that this inverter has to be on for the charger to operateI don't recall this necessity for my Magnum or Xantrex Prosine 2.0 units. While they were physically integrated, they were electrically independent.
I see that if the inverter/charger is directed to the battery charge port and if this port opens, the charger is still common to both the AGM battery and the 12V distribution panel. Switching the connection to the discharge port does isolate the AGM from the charger if the battery is shut off, but doesn't the charger still see the 12V panel? Why wouldn't the loads from this panel load keep the charger in a stable condition like other modern converters that are typically designed to deliver stable voltage even in the complete absence of a battery? I know that vintage converters (Magnetek 60xx?) needed a battery present because it was necessary for reducing AC ripple to acceptable levels, but at this point isn't this antiquated design ancient history?
Yes, it is a stupid design to not have the two functions separate...
The 12v distribution is on the load side, not the charge side so it is isolated from the AGM and the battery charger when the inverter is on the charge side.
There are converters that require no battery to provide a stable output and there are chargers that require a battery connected to provide a stable output.
Converters can provide a regulated voltage without the need for connection to a battery but they can also be connected to a battery to charge it.
Chargers typically require a voltage reference from a connected battery in order to get a stable output voltage (loads wouldn’t help here). Without the battery connection and just loads there is an unstable voltage output from the charger.
With the charger connected to the battery charge port, is there a potential for continuous recycling?
1. The charge port senses full charge and opens the port.
2. The inverter shuts down.
3. The charger shuts down and shoreside 120V pass-thru is inhibited.
4. Unless there are active 12V external loads the system remains in this state
until the internal BMS demand drops battery voltage enough to reopen the
charge port.
5. Battery charging resumes at the charge port.
6. Inverter/charger 120V pass-thru to AC loads is restored.
7. The charge port senses full charge and opens the port.
8. Rinse and repeat.
