OK, I think there may be a way to use stock parts to get a bit higher than the 81004 Moog will take you, which is just under 2" of lift from normal stock or about 35.5" at the wheelwell.
The question would be if someone is brave enough to give it a try to see how it goes. My guess is that it would work well, and from the look of the spacer on the Boulder Offroad site, you would probably still be able to use your original rubber upper mount to help quiet noise.
Here is the spacer page at Boulder
Chevy GMC 6 Lug Van Lift Kits
Moog also makes a 81006 spring that is .621" shorter than the 81004, so if it were combined with a 2" lift spacer, which should be about .858" thick, you get a net gain of .237" at the spring and about .552" at the wheelwell, so about likely 36.25" at the wheelwell when installed and closer to 36.0" after settling. IMO, this is approaching the max that I would want to do for a street van, as the alignment will start to get tougher and you will start to get bump steer if you go higher with spacers.
