I want to show you some alarming statistics or just one, one is enough of what happens when there is an unknown glitch in the system & as an owner, you add a DC Fridge that places a Tax on your system & it cannot keep up.
Bottom line; one day I had a solar harvest from my 250watt panels170 & 80, of 1.25wh & I still couldn't catch up or even get past Absorption.
My glitch; the culprit behind the Fridge not performing during the Heatwave & afterwards, namely a loose ground connection caused by a different RV Guy adding a flimsy connection.
Sorry thst the image quality is poor, at that time I did not realise that Screenshots were already reduced in file size.
NOT THE NOVAKOOL.
My error, in my system.
Plus all those increased figures as I detailed before & Rowiebowie commented is by bringing the Roadtrek OEM SINGLE & OPTIONAL BATTERY bank, INSIDE the Cab, from off the outside REAR PASSENGER SIDE, as close as possible (42 INCHES) to the SHUNT & ELECTRICAL BOX, which on the 2005 Roadtrek 190 Versatile is up.agInst the rear of the Kitchen Czbinet/Rear Lounge Wall on the Drivers Side.
I could have moved it closer but I wanted to keep my Subwoofer & I had already installed the new (2 years ago), MAGNUM MMS1012 Inverter bolted upside down, above the subwoofer.
