booster said:The Dodge models mentioned are chronic understeering, due to the very short wheelbase, soft rear springs and shocks, and alignment specs. Higher front tire pressure, stiffer rear springs, added rear swaybar, reduced front swaybar, are all things that will help the Dodges. Will they ever be as good as the long wheelbase Chevies or Sprinters? Probably not, but you might get them as good as a tweaked Ford chassis.
The test I always use for handling is how much correction is needed at the steering wheel for various happenings, to keep you straight. Our tweaked Chevy is under 1/4" of steering wheel movement needed to correct for trucks passing, wind gusts, road ruts, etc, which is on a par with most cars. If you need to move the wheel over 1/2", you aren't optimized, in most cases. If you have to move the wheel 1" to get back on line, you are going to wear yourself out trying to stay in your lane. With our Roadtrek 190 we can do two fingers on the wheel in 95% of the road conditions.
All vehicles are a bit different, and folks perception of good and bad handling, and good and bad ride, are very personal interpretations. What is good for one may be bad for another, but the rules of physics should let you chose what you want to be to your preference.
This is helpful information. I've taken recent ownership of a 1994 Roadtrek 190 which is a conversion of a Chevy G30. It's already been nicknamed Wanda because it sure likes to wander at freeway speeds. The drive home was pretty fatiguing. Fixing this wander is a top priority. I ran the RT home dry and unloaded, one person with 50# front and 65# rear. (Doorjamb says 50# F, 80# R for fully loaded). At this point I'm not sure where to start. The tires or the suspension? The tires are an E rated BF Goodrich All Terrain. Shocks are softish, but not terrible. Below 50mph it steers fine. Any thoughts of where to begin?
