JohnnyCLE, all AGMs were eliminated, including two upfront. Did not upgrade solar controller because it was programable and just adjusted fast and float charge voltages. With the upgrade to larger alternator, I added a Balmar Regulator and an alternator protection device. Also added a surge limiter to protect the Battleborn BMS from inverter spikes (recommended by Battleborn when using larger inverters). Since I only have 270 watts solar, the amount of charge it supplies compared to alternator is minimal, so upgrading solar controller to specific lithium recommended device did not seem worthwhile. Basically, I still get the at least the same amount of daily solar charge as I did with the AGMs, possible slightly more. No longer needed battery equalizer, since all lithium batteries are 24v and setup in parallel. Battleborn BMS does this and 12v house loads all go thru a converter. Additionally, wiring from the alternator by RT was too small so had to upgrade positive wiring from alternator to junction box and used both Roadtrek (former positive and negative) wiring from alternator as ground wires.
