I am confused a bit about the pic of the tank connection.
The piece shown looks to be tig welded, so the only way it could be brazed would be if it was flanged an then, probably, silver brazed from on the inside of the tank.
IMO that is not a bad way of doing it, although it does have the water and brazing alloy contacting each other. I haven't looked into it but depending on the silver brazing alloy, some might be concerned about leaching.
Essentially all the tanks in the factories are was in were TIG welded to the stainless tanks, or a stainless flange welded on, or bulkhead fitting used with gaskets.
I am thinking of having a tank made for ours to add a small water tank in the rear now that I have space the AGM batteries in place. I have pondered the construction method a lot, and silver brazing was on of the options on the list to check out, with the more surefire welded flange with bolt on mating flange and gasket. Same would apply for an access hole to be able to clean the tank if needed, probably combined with a fill port high connection.
Are the tubes supported internally at all to prevent bouncing? Hard to tell for certain on the drawings.
