96 rialta 2.5 5 cyl gas engine runs bad cold
Budd y
Nov 21, 2015
4
engine idle rough 7 miss will not take gas right no power for about 2 minutes then runs pretty good cleaned throdle body 7 iad any info will help thanks
could be :
your IAT ( intake air temp sensor )
coolant sensor
cold start injector at the intake end ( driver side )
1) verify if you have any voltage at cold injector when cold ( before starting engine but ign "ON")
if so , start engine disconnect it : same or worse
if worse,reconnect, if same could be it …..
next :
disconnect coolant sensor
same or worse ,if worse
reconnect if same could be it ,
disconnect IAT ( intake air temp )
if worse , reconnect …..
Dan
