Switches
55 Nomad
Jul 28, 2020
63
Gilbert, AZ
Where and how are you mounting your switches for accessories like fans, AC override, ETC? Pictures would be great also. Thanks
Here are my locations:
1. Blusesea Control panel
2. Key light switches through electric cabinet lid
3. Main battery power and furnace and water heater
4. Each cabinet light has its own switch
5. Galley outlets, meters, and 300W Inverter switch
Are talking about in the coach or for the chassis. For us, AC override is in the dash in a blank knockout, auxiliary cooling fans, separator control, selection switches for remoter alternator regulator, plus ammeter/voltmeter for charging coach are in the small tray at the center bottom of the dash.
The chassis for starters. I was thinking the areas you said Booster. Can you send me a picture Booster? My lower small tray at the center bottom of the dash is open.
Booster, did your dash have knock outs or was it a open small tray area in the center bottom of the dash. If it was open where did you get the knock out plate to seal that area off and mount switches?
Ours was open, but now full :D
I am sure I have pictures on the forum someplace, I will try to find them.
On edit, found the pix in this thread on our charging upgrade as most of the stuff shown is for that. AC off override is the small red switch under the tow/haul switch.
https://www.classbforum.com/forums/f23/experimental-engine-generator-setup-5982.html
Thanks Booster. Do you happen to remember where you purchased that switch? I have been following along on your upgrades and you always have a professional and knowledgeable way of doing your projects. We have only had our Roadtrek a year so we have a long way to go to upgrade ours to how we want it.
Looking again that looks like a simple on off switch and the on on switch you reference is for the other switches.
