Billyboy46
Wincrasher - you did great reviews on your B's will you do one on the Tiffin? If not in this forum, then maybe in your blog?
When we first bought our Great West Legend SE (Sprinter Based) unit, we read a book that we bought online. The synopsis of the book is that nearly all RV units are bad, and some were just worse than others. Of course, we didn't believe it and bought anyway. We should have listened to them.
Our rig has had nothing but problems from day one--just like the book said, and the video originally posted explained why. That video is a jewel and as far as we can see from our admittedly limited research (from our experience and talking with others on the road), is that it is dead-on.
Are we sorry we've had these experiences? Well, NO. It has been a hell of a learning experience. And, going on the road is really quite fun. The fact that we've had a basic Sprinter as the base of our unit has been a blessing. For the most part they are bullet proof and ours has always got us to the shop for repair (knock on wood).
I would highly recommend the OP's video for anyone considering an RV purchase.
...........Rocky
You are "confident in service after the sale". Is it mostly because you are such an amazingly good customer, Wincrasher? We ordered a Travato 59K from Josh just before I read this thread. I hope the dealership is also good to once-in-a-life-timers. At 225 miles away they are about our closest Travato dealer. I'm hoping we don't get a lemon and will be able to take care of most adjustments at home.
I'm glad you all like your vans so much. I learned so much here from the folks who contributed to this post, so we finally did it. And that was after I read the "death spiral" series. Thank you all.
I would suggest to any newcomer to buy used and fix it up mechanically. Class B's keep a decent value so you likely won't lose out on resale.
This path can save tens of thousands and may limit your loss if you end up deciding it's not for you.
BBQ:
I may not have had any experience with leaking 5th wheels or trailers, but we have had issues with leaks.
Apparently one of the problems with Great West Vans is that the Skylight in the bathroom (which is otherwise a very nice feature) usually leaks. We've had it and it really sucks because the water routes itself anywhere in the vehicle. It's usually not much, but apparently it's really hard to seal up. We've had attempts to repair it three times so far and we recently discovered that it is still leaking.
.......Rocky
My GWVan skylight leaked and was fixed by a dealer in Nokomis, FL rather poorly. So I figured out why and did it myself afterwards. Poor design and sloppy workmanship. What it was, was the skylight was too close to the rain gutter and it was impossible to caulk a bead to seal because the nozzle would not reach. In effect there was a bridge of caulk with a channel uncaulked where the frame met the roof. Any minor leak in the sealant was going to let the water pour in.
A couple of additional thoughts...
If I were buying again, I would look for the following:
- No power step.
- No power awning.
- No power couch.
- No power window coverings.
- No macerator.
- No fancy schmancy entertainment center that accidentally hijacks the electrical system.
My tent works first time, every time.
I don't think that it's unreasonable to expect that a Class B be built to the same standards as the vehicle that it's based on. Class Bs are built in small shops, with every opportunity for hands-on inspection. For every problem that any RV has, it was probably seen by several people along the production line. To me, the real problem is that some in management of some of these companies have decided that quality fit and finish isn't important, as long as production numbers are high. Management can't find the time to listen to the assemblers about ways to improve quality.
It's up to us consumers to let them know that crap is not OK. I know that it's easy to fall for the soft-focus happy couples in the ads, but we need to demand simple things like shelves that fit their cabinets, at the very least. If we can't trust them with low-tech wood, why should we trust them with high-tech wires? We need to demand electrical systems that work reliably. If new RVs cost $5000, it might be acceptable, but with anything costing well over $100,000, there should be no questions about quality fit and finish.
Yes, you can buy used. Still, hoping that a previous owner fixed the quality control problems of the manufacturer seems like it's letting the manufacturers off the hook. There really isn't any excuse for the low quality crap that some RV companies manufacture. They do it only because they know that they can get away with it. They may say that if they had to change their quality standards, the prices of their products would have to increase. What should change is not their prices, but the salaries of the management. Although some may act like it, they're not royalty. They're not going to expand the market by wearing a tiara on their heads.
The RV Daily Report notes that despite millions of new RV's being produced over the past 10 years, the number of RV owners has actually stayed stagnant -- that means that for every potential new RV-er like us one more has dropped out.
