markopolo-ClassB
I thought a very general discussion on improving handling issues might be useful for folks who don't know where to start to correct problems.
I'm not an expert in this.
I'd start with:
1. tire pressures - assuming the tires are still good
2. if equipped with air suspension bags - check and adjust pressure
3. alignment - take it to an alignment shop & get it aligned
4. if there's a shake or shimmy at speed then the wheel balancing could be needed
5. new shocks - heavy duty shocks like Bilsteins should get things like porpoising under control
6. have bushings inspected and replace if worn out
7. install rear air bags (I think I'd do this before installing a sway bar - comments needed)
8. install rear sway bar
9. install new front coils
Hopefully, for your wallet, you won't have to go down too far on the list.
As mentioned, I'm not an expert. There are members here that truly understand this stuff and are very helpful answering questions.
I'd start with:
