Possibly starting a Transit build from scratch
InterBlog
Senior Member
Joined
Oct 14, 2014
Posts
1,179
Location
League City, TX
Our existing Airstream Interstate is now *eighteen* years old (!!), and as long-time DIYers, my husband and I are on the fence as to which way to proceed on a replacement, with our research just beginning. We love our Interstate but:
(a) It’s so old now that system failures and breakdowns seem to be unavoidable no matter how much preemptive work we do, and
(b) More importantly, we have reached the conclusion that we must have AWD or 4WD going forward. It has always been dicey for me to get our rig down the old logging road that leads to the off-grid property I have in the Canadian wilderness, which is our primary vacation destination. We had to cancel our most recent trip because abnormally-heavy rains meant that none of our neighbors were able to get back there without 4WD. I only have so many travel years left in my life by this time, and I cannot be canceling trips because conditions outstrip my van’s ability to handle them.
If we go the route of building, right now we are envisioning a high-roof Transit 3500 AWD with the upgraded suspension package, either long or EXT (undecided in view of the clearance issue).
Alternatively, it is possible that we snag someone else’s good-quality build or build-in-progress because I am open to anything at this point as long as there are no dealbreakers.
A few weeks ago I came across a half-DIY-built Transit on Facebook Marketplace that the owner was selling due to an overseas job transfer. I would have bought that rig in a heartbeat except it did not have OEM AWD, and after an exhaustive discussion with Ernie at Quigley Motor Company, I concluded that a 4WD retrofit was not within reach - not for a van that had already undergone significant aftermarket DIY mods.
So my purpose with this thread is to ask you guys for any words of wisdom that you might have as we scratch our heads and begin this transition. In the past several years, I have not kept up with all of the manufacturers, the new off-the-lot options, pros and cons of various approaches, etc. What would y’all do if you were me? My husband and I do have all the DIY skills needed to pull off a whole build, plus we now have a dedicated separate van garage to potentially build it in, but what we still do NOT have yet is TIME. We are both still working - we are not retired with abundant free time - so a whole-build is not necessarily our default pathway, as much as we would love to take it on. I am not prepared to go out and spend absurd amounts of $$$$$ on something like a new ARV build, but I am open to a lot of other creative possibilities if an appropriate alternate pathway reveals itself.
Thoughts??
Thanks!
Seems like there are lots of 'adventure van' builders out there, most of which don't fully build out the tough stuff - black & grey tanks, wet baths, hot water, etc.
If you can live without that stuff, some or those builders have high quality AWD Transit builds at reasonable prices.
I went through my build in 2013 and here are important points which can lead to success:
  • Clear view of the final product, this is usually missing among DIY community where thinking about next step starts at the finish of the previous step, this type of sequential design often leads to half-finished vans. With your experience it shouldn’t be a problem.
  • DIY camper van’s product development phases are all in one, it is prototype and final product in one embodiment. Good designs on paper are decent substitutes for actual prototypes.
  • First step in a build should be insulation, wiring and plumbing. A well design conduits layout will facilitate future upgrades.
  • Consider subcontracting some systems which are not your forte or cost/time ratio would to be to your advantage. For example, I designed all cabinetry and sourced fabrication, cutting, machining, anchor mounts of practically all 80/20 profiles from the factory and sourced CNCed HDPE filler/finish sheets, which resulted in putting it together was like a LEGO like exercise. 2D/3D design skills are necessary. Grey water/fresh water tanks were custom made.
  • After a complete design I calculated preliminary weights of all subsystems and weight distribution. I bought a 400 scale to keep up with actual weights during building.
  • Maintain good documentation through your build and think about maintenance and troubleshooting during the design phase. I had a water leak behind the galley a few years ago and removal of the galley was a half an hour exercise. Galley was bolted to the floor; all electrical wiring has connectors and plumbing has quick connectors. I designed galley’s frame strong enough that bolting to the floor only was OK.
Would I do it again, today perhaps not, there are more products on the market than in 2012/13 and prices became more reasonable. We wanted an old style Westfalia VW like layout with a toilet, none were available except insanely priced or low quality from custom shops. Spending $300K for a camper van was senseless. We paid $50k for the passenger Sprinter van and over $20k for materials.
I would suggest to search DIY and 80/20 on the Sprinter forum, I think it is the best site for DIY folks, I know this from a friend who is involved with all vans. There is one fellow from Boise (I think) which has a well-designed four seasons van using 1” 80/20 and HDPE on the Sprinter.
Could you provide a couple of examples of such builders?
I would be willing to retrofit plumbing on the right van. Plumbing is relatively easy.
I am not so much interested in style or bling - what’s important is functionality. In fact, I have asked my husband if there might be any way for us to simply shift the Airstream upfit elements plus some of our own DIY upfits from our old van to a new one, because I love the components that Airstream installed - they have a lot of life left in them. Certainly the body shapes are different (T1N Sprinter vs. Transit) but there might be a way to frame and adapt most of that stuff, which would dramatically reduce our work if we went full DIY.
However, even if that could be done, I have not run the numbers yet. If we gut the Airstream, it won’t be worth much. We would save on the corresponding materials for a new one, but I don’t know if the totality of the numbers would end up making sense.
BTW, there are deals to be had if one can be in the right place at the right time. This (below) is why I called Quigley and asked if there was ANY way they could possibly retrofit 4WD onto that thing, but they said no. It was heartbreaking to see that van sold at a loss (mind you, it was significantly upfit - full insulation, all electrical, and interior surfaces finishes all done, and done well). The seller *gave* that van away, but ugh, it just could not be made right for our needs.
You can have a fully functional van in a short time frame if you focus first on needs, then add the wants as time allows.
I have given thought to what I would do if we lost our van. We are 78 and 81. Sure, we are no longer working, but we want to spend our remaining years using a van, not building.
More builders on Sprinter than Transit, but here's a few:
Highline (FAQ says they build on Transits)
I found a few more 'adventure van' builders on a list that I was keeping years ago. Some are still around. :)
This places sells conversion kits.
Well, as you know, I recently completed a fairly elaborate Transit-based build. I didn't do all the work myself, but I was deeply involved. As a consequence, I know the Transit pretty well at this point. Glad to kibitz wherever it might be useful.
FWIW: I have concluded that the Transit is an excellent platform.
In my case, the van NEEDS to be able to:
1. Fully support two adults and a dog
2. In all weather conditions
3. Off-grid
4. In the wilderness
5. For at least 2 weeks without a break
6. With limited-to-no resupply potential for food and fuel
7. While providing us with sufficient options to be able to DO STUFF in those weeks (chiefly terraforming - chain saws and other tools plus the ability to power them, but my ability to run my small business from the van is also non-negotiable, which Starlink Mini has now put within my reach).
8. And all of it with a de minimis level of comfort, because if it’s not minimally comfortable then it’s not worth it. By “comfort” I mean something marginally better than eating nothing but canned beans and weenies every day week in and week out.
^^ A *van* has to be able to meet all those needs. We really don’t look at our primary use case in terms of needs vs. wants. It’s ALL needs because doing the van thing half-way simply isn’t worth it to us.
And there is a good reason why we hold that view. My husband and I have been together almost 18 years now, and by far the best vacation we ever took was 2020’s mandatory COVID quarantine in Canada - two weeks of total wilderness isolation monitored and enforced daily by police. I did leave cash in a plastic bag near the entrance of our property for a neighbor to occasionally drop off eggs and a half-gallon of milk, but that was it. Our van provided everything else we needed, and it was fabulous. Our existing van did deliver on that occasion (although it did take me about 100 hours of meticulous resource planning prior to that trip), but now the thing is 5 years older and my private road is also 5 years older such that I need AWD or 4WD, and here I am trying to figure out the best way to replicate that experience.
Edit: If anyone is interested in seeing what our 2020 experience looked like, go to Instagram @interstate.blog because I posted one pic from each day of quarantine.
Well, as you know, I recently completed a fairly elaborate Transit-based build. I didn't do all the work myself, but I was deeply involved, As a consequence, I know the Transit pretty well at this point. Glad to kibitz wherever it might be useful.
Actually I did NOT know that because I’ve been away from the forums for a minute - thanks for the heads up. I will search for your build details.
My husband (a mechanical engineer) did the research and concluded that the Transit is our best option if we decide to build. I am partial to the Sprinter only because we have a decade of direct and indirect experience with it. We are not married to it, though.
Well, all I can say is that no longer traveling in a DEF-equipped vehicle is by far the best improvement in the quality of our on-the-road lives ever. One doesn't realize how awful living under a Sward of Damocles can be until it is removed.
I test drove a Transit for the first time yesterday morning and my “best improvement” guess is the overall handle-ability improvement. As you know, the T1N Interstate drives like an M4 Sherman. Airstream loaded the thing down to such an extent that it’s almost at GVWR before anyone even steps a foot into it, and its ergonomic design is two decades out of date by now.
Of course I was driving an empty cargo van yesterday, not a developed Class B, but I was pleasantly surprised at how “car-like” it is. The older I get, the less mental bandwidth I have for compensating for the T1N Sprinter’s lack of tech and stability issues.
Additionally, the Transit’s ride was not as rough as I expected. I’ve spent the last decade listening to the wailings of bitterly-disappointed Airstream owners lamenting that their 3500 NCV3 Sprinters seem even rougher than the original 2500s.
The one shortcoming I noted yesterday was that I was not happy with the stock mirrors. I have a camera / monitor system in my Interstate but I tend to rely 100% on its mirrors, which Airstream upgraded in its first-gen Interstate - they are really nice. Once again, that’s an age-related thing - switching my vision to the camera system requires eye focal and ambient lighting adjustments that no longer happen fast enough at my age. I am mostly driving in America’s fourth largest metro where highway survival decisions need to be lightning-fast. I can only do that with mirrors.
Both of those considerations (handle-ability and roughness) are particularly important for me because I am debating whether to pursue this purchase through my LLC and develop a Transit primarily as a work van, so the question becomes, could I legitimately tolerate using this thing as a work-related daily driver in our local intensely-urban conditions? After the test drive yesterday, I think the answer is yes. I would not say that about the T1N, even though I do occasionally work out of it in off-grid situations (and I wish I could do more).
Hi thought I chime in from the West Coast. We elected to bite the bullet and build our own Transit AWD in 2020 and 5 years later we are still 99% happy with the build. There is really only one change we ‘want’ and that is in the renovation stage now. We really don’t like the Lagun table base and I have the hardware to change it but haven’t gotten around to doing it with the rainy weather.
We built a Euro design type van when most van manufacturers weren’t building this van in North America. We wanted a front lounge rear full time bed, hot/cold winterized water, cassette toilet, shower options (we have 3 - inside, front sliding door and rear outside), fridge, stove, heater, awning (wife’s must have) and no other fuel source than electricity and van fuel type. No solar (don’t need with big alternator), no generator, no rooftop AC needed, 400 ah lithium batteries. We also added 2” lift to Transit keeping stock tire size. We store 2 e-bikes plus assorted other stuff under the full time bed. We do have a 14” foot slide on the bed so that the bed is E/W full size queen bed. Roof rack (80/20) for ski box and inflatable paddle board and kayak in summer and skis in winter.
The van is bigger than our previous VW Westfalia and smaller than our PleasureWay at 19’6” but it really works for us for our BLM and forest road camping. My wife loves the drivability of the Transit over the MB or VW.
Hi thought I chime in from the West Coast. … no other fuel source than electricity and van fuel type. No solar (don’t need with big alternator), no generator, no rooftop AC needed, 400 ah lithium batteries. …
Off-grid vans tend to be geographic-specific. In our case, we don’t have the luxury of West Coast weather. We are screwed coming and going - literally. Our trips originate in the subtropics, and it takes 1 to 4 days to drive out of 90-plus degree weather in summertime, so we cannot do without the roof a/c. Our trips terminate in the wilds of Nova Scotia, which spends most of its year being bitterly cold and/or wet, so we have an equally urgent need for robust heating.
And because we are so wedded to off-grid remoteness, we have not yet been able to divest ourselves of energy redundancy, so we still have our propane generator despite having solar and lithium. Every lithium option we have ever tested - five of them so far (two we designed, three next-gen off-the-shelf) - has been buggy. We bought a large Goal Zero right before Christmas 2024 and it became hopelessly bricked in a matter of weeks (manufacturer’s firmware defect, they said, they who Have One Job which is to NOT screw up the firmware). Multiple times over the past 10 years I have been thankful that we did not dismount the “old school” generator. I’ve needed to fall back on it whenever the new tech fails.
Anyway, the tech has come a long way in the past decade, but it’s still light years away from being reliable. I am not yet sure how I am going to compensate for that in our next van.
