I am Costco member but I buy tires at Discount Tire. They will match Costco and service is better. No problem on my Roadtrek 210.
Exactly what we do, also. Great service, easy price match.
Expensive day at Costco today, almost $1000 for new rubber and sensors. I decided to go with Michelin - Agilis CrossClimate ....
I am about to purchase my first replacement tires for my 2015 Travato.
Hi Shiraz,
my impressions on the Agilis for my chev based pleasure way
https://www.classbforum.com/forums/...s-climate-lt245-75r-16-impressions-10460.html
some tire shop want to sell us truck tires for the RV, assume these will be rough riding
we desire a comfortable ride and a quieter tire, so selection needs to take into account the load range and sizes available
then find the people to install
can they lift a tall heavy vehicle?
can they lift with out breaking the tanks!
I used a local chain store Discount Tire and they used 4 x floor jacks to lift the van.
I could have bought thru costco but they were special order...
Speaking with my always excellent costco tire techs, they tell me that the chain is stocking only the most common, high volume selling tires
for all the priuses in a costco parking lot- they no longer carry tires for my prius
cheers, Mike
..... reset new TPMS Dill sensors after they programmed them in with new IDs. .....
RECAP:
George, can you please confirm your van description and your TPMS brand configuration exactly?
-- You stated above a dry weight of 7,000 pounds (which is impressively light). Loaded weight tends to be how much?
-- 2013 Sprinter (NCV3), and it's clearly a 2500 from your website, so only 4 wheels
-- Consistent with the NCV3, you are using a slightly larger but otherwise comparable Load E tire vs. mine (LT245/75R16/E - my older Sprinter takes 225)... am I correct in assuming that you are running in the neighborhood of 80 psi?
These things being the case, what exact Dill sensors and head unit do you now have? What are the specific part numbers?
I am asking because the Dill web widget does not return a suggested configuration for my Sprinter. What DH and I have found generally is that most aftermarket TPMS systems are designed for cars, not higher-pressure tire applications. Therefore I am trying to figure out which system would be best for a T1N Sprinter, and obviously you have one such data point to consider.
Thanks.
Looking to get new tires for my 2007 roadtrek 190? any recommendations? will be driving on pavement and gravel roads.
thanks
