Pilgrim-ClassB
I'm the new owner of a 2000 Roadtrek 190P, which I know (I was told...) needs a new black/greywater dump hose. I've read a number of owner reports on the replacement process, and it sounds easy enough.
My question is about the length and type of the hose. I gather that it's great to have a hose extension in case the dump spot is somewhat distant, and I see that there are hose units on Amazon like the Camco RhinoEXTREME 20-foot hose that comes with two 10-foot sections and a center twist/lock joint. But I'm not sure the center joint will fit into the RoadTrek hose storage.
I also read in some of the replacement "how to" threads that 20 feet of sturdy hose may not fit into the standard RoadTrek holder.
My question is whether I should buy a single length of sturdy hose and shorten it if necessary to get it to fit, or whether a two-piece hose is a good idea. I am not that thrilled about having to store a used length of hose every time I dump the tank.
I'm open to advice and suggestions about what to do in replacing the dump hose. Thanks in advance.
