Electric Radiator Fan
To further muddy the water, interesting testing done by TBSS fellas: https://www.tbssowners.com/threads/factory-ev-fan-measurements-vs-measurements-of-ls1.14101/
of note poster recorded in excess of 10,000 max CFM from the EV fan @3,000 rpm engine speed but despite this, TBSS was still prone to over heating... Easy to guess why though, TBSS has a tiny radiator - 18x26 - and a poor shroud design, whereas tahoe/suburban has same size as express - 34x17 - a 23% increase.
Back to 05+ tahoe setup, to resolve any doubts I had about the swap I performed a number of tests right after install. Normal Charleston morning with 89F and 80% humidity I idled the truck with AC off and fans disconnected. Eventually after 20 minutes or so the ECM finally commanded high speed but truck never overheated, just held 220. I then played with different relay and motor failures (standard 3 relay series/parallel setup) and even one fan on low was enough to keep it from overheating with the AC on full.
Either way, it seems tuning and shroud sealing (which I did a lot of) is key.
My fan tune was copied from stock tahoe which if I recall correctly called for low on @ 195, high on @ 210, low on AC request, high on AC high pressure, fans off over 45mph. I have yet to find any CFM ratings on the tahoe fan setup.
Just a note on the shrouds for the mechanical fans.
I used to mess around with some pretty nasty engine muscle cars like the twin turbo 340 cid Dodge Challenger that I built in the late 80s with all homemade stuff for turbo setup with carb and then aftermarket EFI. 600hp/600tq on a 5 speed Richmond trans. It was wonderful engine but the engine compartment was stuffed with hot stuff so hard to keep cool at idle because the air couldn't get out. I used every electric fan they had in those days and none would do the job either with a 4 core copper/brass radiator or a Griffen aluminum. The Griffen was great once moving but the electrics couldn't cut it at idle. I went back to a mechanical clutch fan with factory shroud and still had some issues.
The "rule of thumb" back then was to have the fan half in and half out at the rear of the shroud and that is where I had it. Checking airflow I found nearly all the movement coming off the blade ends with very little straight back toward the engine. I moved the fan back toward the engine so that the blades were only into the shroud about 1/4" and idle cooling issues went away completely. The airflow coming out from under the car sitting running was noticeably higher.
Today's cars with mechanical fans always have them tucked completely into the shroud, presumably, and wisely, for safety reasons. It does appear to cut down the flow a bunch. What can be done safely is to window out sections of the rear of the should and cover them with finger safe mesh to let the air out.
I really don't understand why GM turns on their fans at so high a temperature. I went through this on my 1996 Buick Roadmaster wagon that has the old reverse flow cooling 5.7 engine. The reverse flow makes the sensors and thermostat read differently, I think, so they are really high at 215 and 227*F, when the engine on thermostat runs about 198*. You get a constant cycling up and down that hot at stoplights and it is warm enough that in hot weather the alcohol laced fuel starts giving stutters at stop sign leaving. I tuned them down to 204 and 210* with my tuner where the 204 is just a bit above what the sensor sees on hot days at highway speeds and now it runs great all the time.
The Buick runs the small fan continuously when the AC is on and it never goes above about 202* it the hot weather. My high van essentially never comes on. This is with a 1.25" thick single core radiator which is the middle thickness of ones they offered on different cooling packages.
One thing to consider is that for as long as I can remember vans always run hotter than their full engine compartment cousins like pickups and SuVs. The small van engine compartment just can't get the air out fast enough, it appears. There is a discussion on here about adding side fender vents to let air out of the engine compartment, and I have considered doing it, but haven't to this point.
I did a quick look a while back at the efficacy of installing side vents (in the fenders). I believe more body work hassle than benefit gained. In my Chevy 2500 there are several "layers." Not just metal, but also the obligatory "plastic" inner liner(s). Not to mention the engine is so far aft, no effective "venting" could be accomplished as it is virtually in the cab.
So, since my under hood cooling experience has been with race cars, I see 3 EXIT locations of reasonable merit. All located in the hood. The pic shows the 3 and the cabin air intake (as I understand it).
attachment.php
If I didn't have another ongoing (major) project, I (very briefly) considered picking up a used hood for about $100, doing some surgery, and providing some real answers. The alternative of doing a CFD study is still to involved for my workload. Perhaps someone else could be persuaded to cut some tin.
For a test protocol, my thought experiment identified a few key measurements; OAT, engine bay temp, various speeds, with baseline hood, then with modified hood, and modified hood with fans. Comparing bay temperature and temperature at the outlet and near the alternator(s) would be useful too. My data would be unrepresentative, as my modification eliminating the entire shroud and mechanical fan, and replacing with electric fans, would not represent a true baseline. Also, my Short Ram Air intake frees up a sizeable volume in the engine bat formerly used by the air filter canister and assembly. Also why I am seeking a smaller coollant reservoir.
CABIN AIR INTAKE (Area 4): The rubber gasket does seal the hood from the cabin intake, so the #3 area would still be a "last" choice, require some clever aero "shaping." Areas 1 & 2, however with some cleverly designed louvers, perhaps a couple of small pancake fans could provide much measured relief.
Perhaps adding additional air INTAKES could provide some relief? There would be a drag (and MPG) cost, but just like adding brake ducts in a race car similar devices could add atmospheric (not engine heated) air to the bay? A 4 inch hole saw and some drier ducting - Bob's your Uncle! Again I'd look for similar test protocols.
Any Takers?
Cheers - Jim
Correction
VDO 7/9 blade FA70620 is listed as 2963 CFM
VDO 5/7 blade FA70618 is listed as 2712 CFM
For reference VDO site also states lauded crown vic fan as only 1562, old LS1 dual fans were in the same range.
Only way to get more CFM would be FlexALite claimed 3000 cfm 16 pullers but at $155 ea + shroud, it seems the OE solution would be the best bang for the buck
Just a few quick ones;
The Fuse Panel tap locations for the Extreme Electric Fan Controller (Stage 4) I installed:
attachment.php
Here is a quick shot of the controller mounted in a "Dry Location." OK it is under the hood, but I fabricated a weather resistant cover:
attachment.php
A diagram of the controller and the connections:
attachment.php
An observant reader will note I got my colors out of the crayon box mixed up The yellow/green are not coordinated between the 2 diagrams. To lazy to change it.
And as a finale; a paste up of a hood "concept" with a similar vehicle CFD. Note the lower pressure zone midway up the hood - that is without an opening. That region would "fill" and draw air from the engine bay. Just as the earlier versions 1 & 2 would.
attachment.php
Here is a link to fender vents, but be aware there is typo that says they are air inlets, when the really are exits that help the radiator fan push through the air out of the engine compartment.
3549%2013%2012%2011%2010%2009%2008%2007%2006%2005%2004%2003%20chevy%20express%20van%20custom%20fender%20vents%20sport%20design%20conversion%20gmc%20savana%20sarona%20body%20kit%20kits%20.jpg
Yes. And, I "get it." And, there might be some lower pressure to help vent those in that location. But as I survey the area, without pulling the fenders, and then opening the inner fender - to match, those will only be venting the space between the outer fender sheet metal and the inner fender - not the engine bay. Perhaps some ventilation of the wheel well - but also slight. I concluded this by looking through the open door to the inner/outer fenders. Plus on the 2500, there is a "lot of stuff" in those areas - air conditioning on pax side, ecu, brake cylinder, etc.. Vehicles may be different - but on a Chevy 2500 - the fenders would have to come off.
It would, in my opinion, be more profitable (small business op here?) to splash a carbon fiber hood, following testing of the sheet metal tests I proposed. That would be my approach. But then again, I am more of a 'Glass-man than a Panel Beater. And, it would keep the vehicle in service longer.
Cheers - Jim
3797%202011_2012_2013_2014_2015_chevy_express_gmc%20savana_van_custom_sarona_body_kit_fenders_roof_trunk_wing_side_skirts_add_on_lip_front_rear_bumper_grill_kits_bumper_cover_front_rear_customizing_.jpg
Nope - never seen those before on an Express Van. I've seen that one on other cars. Sometimes called a "snout" or, a snorkel. These were on some of the muscle cars like the Pontiac Firebird, for one.. As a forced air intake, it could be good for a ram air for power/performance, and some additional fresh air into the bay. But, then the challenge of exhausting that air is what increases underhood drag, and reduces MPG with little change in underhood heat. Nice looking, though.
sadpanda;148297or better still said:
https://weldtecdesigns.com/product/wtd-chevrolet-express-fiberglass-hood/[/url]
ironically the most reasonably priced thing I've seen from them
WoW! Not cheap at all. Looks "cool" but for removing underhood heat, would definately need to be opened.
As presented, both of these appear to me as; styling items. They are offering look and more form than function. This second one, with the left and right 'flats' on the hood opened judiciously, could offer look and function.
For example;
R.24d2338ca5d807a8191019943287b0df
But for now, these are just my opinions.
Testing and temperature measurements would be useful for decision making.
There might be some business op here.
Thanks for bringing those in.
Cheers - Jim
Im assuming you have seen this:
https://www.sarona.com/Chevy/Express_Van/wiper_cowl/Hood/
or better still, this looks like your desired design, just needs cut open
https://weldte
cdesigns.com/product/wtd-chevrolet-express-fiberglass-hood/ ironically the most reasonably priced thing I've seen from them
I have not looked at all that they have to offer, but the front to rear slotted bulge hood would certainly what I would pick to evacuate the engine compartment, rather than pressurize the inlet like the other options. Of course you would open the sides of the bulge to pull out the air compartment air.
Airflow is very picky a thing and getting it to help you can be a big benefit, but if it hurts you it makes things worse. Been there, done all of those options.
The other pics of the front scoop hood would be good for force feeding the air inlet to the engine but not for compartment cooling.
A quick sketch if I may:
attachment.php
That would work, but IMO you would need to turn the louvers around to the face the rear if you want to evacuate air from the engine compartment. Putting more air into the engine compartment is going to reduce the air through the radiator and that is not a good thing.
That is just an illusion created by my crappy shetch. Those lines are hastely drawn, to show what may be a viable location for louvers - areas 1 & 2. Those are indeed exhaust louvers - not intakes. They must be facing aft to allow flow out of the engine bay. Additional high pressure in the engine bay would - yes interfere with radiator cooling (unless ducted elsewhere for exit) and cause a major decrease in fuel economy.
I felt no need to make a CAD correct presentation - just a "Quick Sketch" regarding placement. I thought this image in the earlier post made that orientation clear:
There are a number of after-market louvers that could be purchased for this.
I still believe a test would be worthy before committing to an expensive modification to a $700 fiberglass hood!
Good fun and some information clarified - I say. :dance:
Here's a quick "Experential - Update"
Just back from a short 1200 mile circuit. Got to catch up with some old fighter buddies in Nashville. I say old - because I was surprised how they aged!
We had the unfortunate situation occur. The hood latcjh wire had stretched beyond functioning. I had a screw driver; just long and skinny enough to trip the latch.
So now what? A bit of #12 primary wire and a zip tie for good measure and now it hangs on the "safety catch." Not the best, but good enough.
We returned to base (and drove the rest of the week with it too.)
Quick posting of results:
At highway speeds (65-75mph) and the OAT (Outside Air Temp) ranged from 78 to 98 F:
Measured engine Bay Temps ranged from a low "Delta" of plus 8 degrees F (above OAT), to a high of plus 12F (over OAT)
When stopped (and not moving) the temps rose - as would be expected - no ram-air cooling. Up to 40F over OAT.​
I am convinced the electric fans I installed (post:
electric-radiator-fan-13904.html
ensured the engine temps remained "nailed at 195-200F" as per previous experience. Also, as they are shrouded directly in the radiator no loss in radiator cooling due to the additional engine bay airflow.
I have a few pics of the wire-tie situation and will post when downloaded. Also my refit of the catch when accpmplished.
It gives me added recognition of this possible solution to underhood heat:
attachment.php
It seems to be one of the simplest approaches. BTW - we noticed NO increase in cabin heat as might be expected because the heat would have been exiting at the windshield already mentioned previously into the cabin-air pick up. Cabin-air remained ambient and as it warmed with the OAT -we used the AirCon.
Hope this helps add some data - though vague at best, it is based on experience. If concers about ram-air exit remain - other openings could be created with some effort!
Cheers - Jim
attachment.php
Cheers - Jim
Our 1970 Dodge Challenger had a similar hood scoop setup although a bit closer to the windshield and a bit smaller. They were originally designed to be air linlets to a dual snorkle air cleaner but Dodge never did that so they had metal covers in them that were removable. With the twin turbos it ran very hot under the hood when sitting still. I opened the scoops and it ran a bit cooler when sitting still, but I found it pressurized the area behind the radiator when driving and cut down radiator and intercooler airflow through the front. Basically traded cooler idle for warmer driving temps. They also also dumped lots of water, bugs, and other stuff in the engine compartment. Also very much like some of the Pontiacs of the past, and also like one of the aftermarket hoods for 96ish Roadmasters and Caprices.
On the van I would think they might work OK with smaller size tubing to the rear of the alternators where they take in their cooling air to help them run cooler without pressurizing the area radically.
We need a new hood due to acorn dents but that would is pretty high on the price scale, I fear, even though it looks nice. If the scoops when the other way so the air was pulled out, it certainly would help heat all the time, but might come in the cabin inlet.
I wish we could run without the inner fender splash shields without messing up everything under the hood with splash. They would really let a lot of air out.
{booster}I opened the scoops and it ran a bit cooler when sitting still, but I found it pressurized the area behind the radiator when driving and cut down radiator and intercooler airflow through the front. Basically traded cooler idle for warmer driving temps.
I didn't experience the reduced radiator cooling from a pressure build up because the electric fans are sealed and shrouded to the radiator. Enough airflow to keep the water temp correct, and mix with outside air from the opening to bring the underhood temp down. Also, the Alternator Case Temps remained within 140F-180F while moving. At that high end in stop and go traffic. I will confirm today that the probe is still onj the case.
{booster}They also also dumped lots of water, bugs, and other stuff in the engine compartment.
I haven't checked yet. On today's list of "to-dos!"
{booster}On the van I would think they might work OK with smaller size tubing to the rear of the alternators where they take in their cooling air to help them run cooler without pressurizing the area radically.
Naturally the existing intake will be in the way. My "short CAI" steup opens up all that volume and it would be preferable to build-in some duct-work inas part of the hood to direct flow.
{booster}We need a new hood due to acorn dents but that would is pretty high on the price scale, I fear, even though it looks nice. If the scoops when the other way so the air was pulled out, it certainly would help heat all the time, but might come in the cabin inlet.
Hmmm. Sounds like you might have an item that when replaced could be worthy of "modification," with some A-B-A testing.
Cheers - Jim
I probably should have been more clear on the pressurization being only from the ram air style hood openings. Pressure from the fans is a good thing as it will force the air out of the underhood area. With ram hood whatever pressure it generates subtracts from the pressure delta across the fans and radiator, reducing flow. The previously discussed rearward facing louvers would reduce the pressure and increase the radiator and fan pressure delta so increased airflow and the hottest trapped air would get out the top of the compartment, but with the risk of winding up in the cab of the van.
On the Challenger, it didn't get hot when moving from the pressure of the vents, where it showed up was in the length of time it took to reduce the temp from an idling at a stopsign type increase which was the biggest issue.
Regardless of the hood openings, I found the radiator style to be somewhat counter intuitive in the car. Over the years I had two primarily used radiators for it, a special built 4 core copper/brass one, and a Griffin 2 core max cooling one. Aside from the materials, the biggest difference was the fin count/spacing. The copper/brass one had the normal tight spacing, and the Griffin had very wide spacing for more airflow. The copper brass cooled better at idle and low speeds, and the Griffin did better at over about 20mph because of the higher airflow from less air movement resistance. The low airflow and higher heat removal from the radiator of the copper/brass radiator made the underhood temps soar very quickly at idle.
I still think the Sarona side vents would be a good way to get air out engine compartment, though, as they would be in a low pressure area and would not get into the cab unless the window was open all the way, I think. Of course, the inner fenders would have to be modified as we talked about earlier because of the gap between the inner and outer fenders that goes all the way to front of the van. I think spray foam might be a good way to go with that if high temp stuff could be found.
Do you remember the road race cars that somebody mounted a small gas engine in and had "propeller" type fan to suck the cars down to pavement tighter? IIRC they got banned very quickly. That would probably keep the engine compartment cooler :eek:
Hmmm, maybe small fans in the Sarona side vents would work a lot better.......:whistling:
booster - all clarified and good points. Maybe some small 12v pancake fans in the side openings? Snap thermostat to turn on.
The Jim Hall Chaparrel 2J. I'm a big "Fan" so to speak. It wasn't just a downforce advantage, but a "perceived Thrust and all the road debris was deemed unsafe as I recall.
A few years back a couple of gearheads put a fan in a C-3 Corvette from an Abrams tank (surplus). Won the $2000 grassroots challenge! But banned for normal competetion.
Cheers - Jim
As previously promised... Hood Latch Mod
Once I got the spring off the latch, I was able to get the hood opened. To keep from having to use the "just-long-enough-barely" screwdriver again, I wired the latch open:
attachment.php
Cheers - Jim
