I think this is what may be happening. The propane flame has to somehow be set up to provide enough heat for the absorption process to happen but not too much to damage the heater/coils. That's a guess on my part. So when you turn off the propane, the boiler heat starts to cool rapidly. (Think of a gas stove. There is some residual heat left in the pan but maybe not enough to give you an effective browning or frying heat. ) So at that point, the fridge starts to lose its effectiveness for cooling. You now switch to electric (either 12v or 120v). Those heating elements are not instantaneously at peak temperature. so they take a while before reaching the temp level to effectively produce the heat necessary to get the absorption process rolling at full steam. During this transition period, your fridge is essentially off.
Propane mode on this fridge cycles on and off to maintain the temperature in the fridge and that's done by a valve in the thermostat (the gas line goes physically through the thermostat body). The flame doesn't go off rather it cycles from "high flame" to "pilot." I visually verified this after replacing the thermostat. In electric modes it does actually turn off current to the heating elements. I also verified this using a volt meter. The meter gave me a c.120v reading when the thermostat was at MAX and 0v when at the lowest setting.
