Subtitle-"yes, the factory service manuals can have mistakes".
Not related to our Roadtrek, but certainly could apply to lots of other vehicles, including other class B models.
I went to change the coolant on my 96 Buick wagon yesterday, and figured no big deal, and easy, but messy, to get a complete change as the knock sensors are in the old block drain location. Pop them out, drain the radiator, fill up per the factory service manual procedure to prevent air lock and be good to go.
All went as expected until the last step, fill it back up and bleed air. Manual says fill through the surge tank as there is no radiator cap on this model (reverse flow cooling also) while the little air vent on the thermostat housing is open until it spits liquid. Check. Leave the surge tank pressure cap off and run the engine until it quits bubbling air back into the surge tank, and the bleed valve is all water, making sure the thermostat is full open and the heater on. OK, that is easy, except for the minor problem (figured out way too much later) is that without the pressure cap on, the engine will make steam in the the heads before the electric cooling fan comes on. At first I thought it was hot spots because of air trapped in the heads, and cleaned up the semi major boil over mess, added more anitfreeze, and tried again. Temp gauge was well within OK range through it all, but a bit higher than thermostat temp. Water coming out of the engine was at 190*. After wasting 1/2 gallon of antifreeze and mopping it up off the floor, I turned on the defroster so the AC compressor and the electric fan would run continuously regardless of temperature. Temp dropped a little. Worked perfectly, no boil over, last of air came out, and good to go. I repeated it all the next day, but with the pressure cap on, and all was good.
I know many vehicles let the temp go up 10-20* before they turn on an electric fan, so it is very possible that they might do the same thing. It probably all depends on how the heads are designed and cooled.
I will be doing DW's 2009 CRV next week, and the factory manual says to fill it per their procedure and then run it with the pressure cap on, but loose, until the electric fan cycles at least twice, and then refill and be done. That would imply that the fan setting is lower than the steam making point without pressure, I think. I certainly hope so, I am running out of paper towels to mop up the mess.
