Any water you move into your system with the pump needs to be cleared out- I'd wait on that until you are closer to using the water system
the pump should have a filter on the right side of it- check that
The manual describes draining the water system ( water left in the tubes can form bacteria, like Legionella) or refer to that pdf I posted earlier for you
To drain hot water tank, remove the anode, either 1 1/16th or 1 1/8th socket ( can't remember) anodes are cheap on amazon. once out flush with a hose to get any residue/mineral deposits out. replace anode with ptfe tape
sanitizing the water tank- I do this about 4 days before trip- I use a couple of tablespoons of pool shock tri-chlor ( because I have a pool) some use bleach.
I put in the tri-chlor and 1/2 tank water ( about 14 gallons) and then go for a little drive to mix it up. I let it sit in the tank overnight for crystals to break down & the chlorine fumes to do their thing. ( maybe bleach is faster)
run the pump and open taps to get air out and water through all the lines- turn it all off and let the chlorinated water sanitize. I will then fill tank and drive to mix it around. let it sit.
( these drives are usually to costco to get supplies, gas and check tire PSI)
day before trip, run taps some. then dump water from tank.
hook up city water and run through all the taps until you can't smell chlorine.
your tanks should have started clean so you can dump in the driveway.
before trip, where are you going ?
if you know there is water there, then just put a few gallons in the tank- no use hauling 300 pound of water around if there is water there. if no water there, fill your tank.
so this takes planning
we use the water in our tank for flushing, washing, cleaning and cooking if boiled
we carry empty gallon jugs and fill with known good water to drink
