Battery will not turn off, 1998 Roadtrek 170
Kinch-ClassB
Advanced Member
Joined
Jul 26, 2019
Posts
32
Location
Colorado
Hi all, I'm having an issue where my battery will not turn back off (the cabin battery that is turned on from the panel switch). It had run down so I connected to shore power overnight, disconnected in the morning and all was working fine off of battery power.
I then clicked the switch to off but the on light and battery remained on. I flipped all the breakers in the back (from the panel under the lounge) off but the battery remains on and has drained again so I'm scratching my head here.
Any advice would help, please and thank you
Have read up on the switch and how to troubleshoot but where is the disconnect switch located on the 170 if anyone knows...
Got the same issue on a 2013 210. I have to start the van and then turn it off again to get the light off. Also, make sure the inverter and all panel switches are all off.
The disconnect relay will not change from on to off if there is power coming in from Shore/Gen.
Kill all incoming power and then try to switch it.
The relay is a magnetic toggle and is magnetically "frozen" in place when Shore power is applied.
This is why the warning says to select "ON" before plugging in shore.
The relay "latches" by a magnetized metal rod pendulum swinging in or out to latch it on or off.
Shore power "swamps" the magnetic field and prevents changing states of the relay thereafter until shore is removed.
With Shore removed and batteries charged (takes 12Vdc to switch) the relay should switch.
If not, there is a failure to find.
Why would you want to turn the batteries off while plugged into shore power. The shore power charges your batteries while you are plugged in. If you want to store your RV and turn the batteries off, you can do so if you are not plugged into shore power.
My 210 would do this without shore power, RT couldn't explain but it works.
"..My 210 would do this without shore power, RT couldn't explain but it works..."
?? Do you mean it would freeze up even when there was no Shore plugged in?
Or that it would switch even if shore plugged in?
Not sure if you're asking about the 2013 210, but with shore power unplugged and the battery disconnect set to off, the blue light remains on. RT told me to start the van and it should go off, if not turning it off again works.
I should add that my 2013 210 has dead house batteries which may be the root cause for the anomoly.
I believe that is correct.
When you start the Van, you will get Voltage from the engine alternator that will, then, let the switch have the power necessary to effect the switching.
I don't think the circuitry in the 90's Roadtrek was all that smart. I have a 1997 170P, and it's pretty basic. The latching relay just disconnects the battery, regardless what else is charging it (solar controller, shore power converter, or diode isolator). So if any of these are on, you will have live load circuits but no battery. And that can be a problem, since some chargers reach much higher voltages with no battery connected.
Don’t know why but it works ...
Don’t know why but it works on my ‘96 Popular 210. If battery red light won’t shut off simply restart engine and then shut down. The aux. bat should now shut off when turned off. Hope this helps.
Actually the smartness was coincidental to the charicteristics of the relay and coil.
Pretty sure some of these side effects were not because of any design intent.
It just came as a part of the magneto-physics of the relay lol.
Kinda like getting something for nothing.
Not being familiar with each and every relay employed in RT Vans;
am not sure what the earlier designs used.
This is the relay I am amplifying upon.
media
media
