air shocks
BigDan
Sep 7, 2014
258
I plan to install some air shocks on my 2000 FD Rialta .....
no listing but the Monroe Max-Air MA830 are so similar to our dimensions ,that id like to try some on ....
personnaly I think it could help the air balloons or maybe even replace them .....
Ill wait for spring to try these on ......still freezing cold up here !
Dan ,
The best thing to do is make sure you have clearance for the movement of the shocks. Also where will you place the air valves? On a 1986 LeSharo, I replace the rear shocks with coil overs because there were no air bags at that time. This helped with keeping the rear end from bottoming out. I also added overload springs, that I purchased from AutoZone for $30) to also help with rear end sag.
when i stored it for winter , I looked under ,...there is ample space for air shocks ....
I think that combine with the air bags it should give great service .....
coilovers : the real solution ,but expensive !!!!
On this topic, I have an air input on each side of my 98 RD. I think these are for the air suspension? One is missing a valve stem. Where would I get a replacement? Bike shop? Tire Store?
no valve stem ,????
better verify the air bags then ,,,,,might be ripped
you definitely need those air bags
the valve stem is a regular item any tire valve will do !
Dan
