xanadu1jw
Hi everybody, I am new here, 64 year old grandmother and I hope I can get some help. I have a new (to me) van/rv here and though the salesman started the generator easily when I was looking at it to buy it, and although it sounds like it is making a nice healthy sounding try, it won't start for me. The manual says if it won't start from the button inside the van to start it from the button inside the access panel of the generator itself. Not being mechanically knowledgeable it took a bit of advice from someone on FB to look for a smaller exhaust pipe to even find the generator after looking everywhere else I could think of including where it sounded like it was, all the storage bays, the engine compartment, etc. So it is in the center rear of the van under the floor in front of the hitch and I don't see any way to get to any access panel if I could even see one. So I called the former owner and she told me that they couldn't ever find the generator either and just started it from the switch inside. Then she contradicted the manual which says if it is not a diesel van then the generator runs on the same gasoline the van runs on, she said no, but that when they had trouble starting it they were told it must be low on propane so I went to Flying J for propane. The seller also said she was told to only fill the propane tank 80% full. The button on the panel for LPG said 3 when I pushed it, not 03 or 30 just 3. So the flying J guy said he always just fills them till they are full. So I watched the panel reading and stopped him as close to 80% as possible although the reading said something different higher & lower each time I pushed it. FRUSTRATING! So it got about 3 gallons into it. Got home and the generator still wouldn't start. Just makes that sound that says it's trying. Followed the manual that says just push the button for 10 seconds and then wait 30 seconds. Did it four or five times. Oh and the panel reading says the battery is at 12.5 so I don't think that's it. . Fooey!!! Darn Heck and Drat! Any help here?
Okay to prevent anyone else from having to read down through all the answers below Avanti in his answer below provided me with the info I needed and the generator is now WORKING!!! SO HAPPY!!!
