looking at a 2008 roadtrek chevy 190 which has a rust hole in the frame. its gonna be sold to a salvage yard but i was thinking of seeing if its possible to have a friend with an autobody shop weld up some plate. i went along the frame on both sides using a screw driver and a hammer to see if i could find other areas but it seems ok.
i would imagine its not easy to replace the whole frame like a toyota truck in that everything is built on top of the frame ?
is this a common issue with roadtrek or with chevy roadtrek's ?
the rv is mint inside and out and worth $35k and the salvage yard is offering $7k
am i nuts even to consider it ?
