07-26-2019, 02:11 PM
#141
Originally Posted by mumkin
I'd say that this the number one reason that the major converters have dropped the Chevy. Takes up a lot of space and time on the factory floor. Rapido did not choose to go into the old RT factory that has those facilities already... which is why I expected the Chevy to disappear from the lineup.
Odd the positive talk about the Nissan van... probably the butt ugliest van ever built by any manufacturer... in the world. It makes my Promaster look like Marilyn Monroe. And I literally never see one on the streets of MN or AZ, nor on the highways in between.
Interesting, as we live in the outer ring of northwest suburbs of the Minneapolis area (blue collar end of town), and I have been seeing more of the Nissan vans lately, which had surprised me. I certainly agree on the ugliness factor, though.
07-26-2019, 03:48 PM
#142
Sorry, we're getting WAY off-topic here, but the Nissan doesn't hold a candle to the Citroen Type H van ( https://en.wikipedia.org/wiki/Citro%C3%ABn_H_Van), much a no other car I can think of can hold a candle to the Citroen 2CV ( https://en.wikipedia.org/wiki/Citro%C3%ABn_2CV).
07-26-2019, 05:16 PM
#143
And just to show there's no accounting for tastes, I actually kinda like the Nissan's boxy style. See quite a few in my area thanks to an aggressive local Nissan dealer and... ahem... large families. None in work duty, but a couple of DIY camper conversions. Reliability is an issue from what I've heard.
Promaster is the one I'd call face-ugly if not quite butt ugly...
On looks alone, I'd choose the Metris. It may actually have a chance to make it into the Rapido/Roadtrek North American lineup.
2014 Roadtrek 190 Popular
2008 Scamp 13
07-27-2019, 02:27 AM
#144
For me, the dual wheels were an essential safety factor
Pick whatever vehicle makes sense for you...
I wasn't going to look at any Class B without the dual wheels in the back.
It feels more stable to me in turns and also in crosswind situations.
Your might disagree and that's fine, but, I like it.
Also, there's virtually no way I can overload the van especially with the rear payload.
07-27-2019, 02:28 PM
#145
I currently have a Class B in design that deliberately eliminates duallies. Besides the design necessitating the layout without, I always thought dual wheels in the back to be a pain.
07-27-2019, 03:46 PM
#146
I agree. I think you can now purchase a 22 foot Transit with single wheels. Maybe an upfitter could be careful with the weight and avoid dual wheels.
08-03-2019, 12:46 PM
#147
I do not think you can get very far with very much upfitting with a single rear wheel weight capacity. A basic van with a basic bed, sure. But a Air conditioned, heated, van with a high top.. not likely.
A single rear wheel extended van with a high top has a capacity of 3605lbs while a dual rear wheel (which also adds stability has a weight capacity of 5154lbs.
08-03-2019, 01:30 PM
#148
Trying to find a way through all the Ford inconsistent and contradictory specs is like playing hide and seek in corn maze.
They list that they have 9400# gross available as a single wheel but then in the this chart they don't show a 9400# only 9500#. Load capacity on the 9500# high roof extended shows 3920# single wheel rating which is not too bad and similar to what the single wheel conversions in the past would have been on Chevies and Fords.
https://www.ford.com/commercial-truc...passenger-van/
My guess is that Ford is getting pushed by the trades buyers, as they seem to want single wheel rear drive for jobsite traction over duals, and they want load capacity similar to what they have had with the Chevy and Ford vans in the past.
Personally, I don't particularly like the way dual wheel trucks drive, and would always opt for SRW is possible.
08-03-2019, 03:17 PM
#149
I think you can, everything is just going to have to be smaller capacity and lighter... and likely much more expensive. I'd be curious to hear what the limitations were from David, the cost difference for an Advanced RV may not be indicative given their high price.
08-03-2019, 03:53 PM
#150
Dubbed "Mies - Less is More", I think I got as much capacity and features in a van 5 feet in length smaller than my current extended body 3500 Sprinter van.
I could duplicate my design with any 144 2500 2 WD Sprinter van with any company willing to take it on or I could DIY (not willing). Only Advanced RV was willing and have the things I want and the quality I'm accustomed to. That's the only difference.
Limitations? I'm not getting VB Air Suspension or 4x4. I'm not getting the levelers ARV offers. ARV needs to deliver a base cargo van at 5,000 lbs built out at no more than 7,400 lbs but with a 9,100 load capacity. So I have 1,700 lbs to work with. I can envision only about 800 lbs I can add (people, clothes, toys, kitchen items, food, water, etc.) so I have another 900 lbs to work with in additions. So after I take possession I am free to add levelers and VB Air Suspension If I want. Or I could add a roof rack and ladder. I doubt I would add the VB Air Suspension since no one rides in the back.
08-03-2019, 07:04 PM
#151
I built Westfalia like layout fully loaded way under the limit on 144” WB 2500 Sprinter. With additional roof AC and full-size shower, I would still be way below. Increasing fresh and gray water tanks volumes, adding LPG tank would require decreasing road clearance which would be against my objectives and would get me closer max.
Main weight reduction was achieved by using lightweight aluminum framing with thin HDPE side panels. A production conversion using welded aluminum framing would be even lighter than my 80/20 extrusions and considerably lighter than 5/8” – 3/4“ plywood, MDF, particle boards, or hardwood.
08-04-2019, 01:25 AM
#152
"So I have 1,700 lbs to work with."
For contrast, my Roadtrek Etrek has most of the bells and whistles including 8 AGM batteries (probably 600-700 lbs) and the specs say I still have 2500 lbs for occupants and cargo (including water). I doubt the difference would ever matter since, as you indicate, we are unlikely to ever carry that much weight, unless we decide to tow something.
08-07-2019, 01:40 PM
#153
Sure, its possible with minimal systems. The problem is the european approac of lighter, smaller = better is just a trend that has come into the USA recently. Prior to this everything was larger = better.
Nice build by the way!
