Old 02-26-2007, 08:53 PM   #1
Default Road-Trekking Motorhome
Travel Road Test: Chevrolet 3500 Van
Road-Trekking Motorhome: Luxury Meets Four-Wheel-Drive Utility
By Lazelle Jones
Truck Trend, December 2006
Link to Full Article: http://www.trucktrend.com/roadtests/van ... index.html
Home & Park Motorhomes of Kitchener, Ontario, has married the creature comforts of a motorhome with the utility of four-wheel drive. Filled with the amenities the luxury-RV lifestyle is known for, the new Roadtrek 4x4 190 also can get you to some primitive campsites.
By adding 4x4 capability to this motorhome, Home & Park has taken the possibility of adventure to a new level. An RV that features a full galley, bathroom, and king-size bed, this Roadtrek 4x4 maneuvers just as easily along rough trails as it does through congested urban settings. Furthermore, when not being used for adventure, the Roadtrek 4x4 can transport the soccer team to its next game or make runs to the market. The secret to this union is the chassis/platform Home & Park elects to use.
Beginning with a Chevy 3500 van chassis that comes equipped with a GM factory rear locking differential, 4.10:1 rear axle gears, and a heavy-duty transmission cooler, the empty van shell is augmented by Quigley Motor Company of Lancaster, Pennsylvania. Quigley adds a full four-wheel-drive system by swapping in a General Motors double-wishbone front suspension and GM two-speed transfer case from a Silverado 2500 HD pickup truck. Drive choices include 2WD, 4WD High, and 4WD Low, and it has a Neutral detent. For convenience, you can shift from 2WD to 4WD High at any speed, but must be stopped or running at speeds less than five mph to shift into low range. This system is intuitive, friendly, and easy to use.
We set out to test a Roadtrek's mettle in the rugged backcountry of southern Utah. We lived in the RV for more than a week and covered 1700 trouble-free miles of Interstate, city, mountain, and rough roads. The Roadtrek 4x4 190 took us off the beaten path wherever we found a dirt road and did it all while keeping us wrapped in a cocoon of luxury.
To support stand-alone RV camping, Roadtrek provides a 2.8-kW auxiliary generator that draws its fuel from the chassis fuel tank. The generator can power the 12,000 BTU roof air-conditioner, three-way (AC, DC, propane) refrigerator/freezer, microwave oven, and LCD television. However, it also has a 750-watt inverter that draws its power supply from a separate house battery. The inverter is designed to power the television/DVD player and other small appliances.
