Old 05-26-2020, 09:00 PM   #1
Default Woven vinyl or coin grip flooring - any insight?
Hi All,
I have a 1994 Chevy Falcon Sport that we are beginning to remodel. We are going to remove the old carpet and are looking at options that will be easy to install, maintain, and clean. We have several bends, nook, crannies, and steps so both of these options seem like they would work well in that application. I'd like to avoid as much saw work as I can. Here are links to both:
https://infinitylwv.com/blogs/infini...y-lwv-flooring
https://www.recpro.com/8-6-nickel-pa...looring-black/
Has anyone installed either of these, and if so, can you provide some feedback? Also, any other suggestions to consider while replacing the flooring in a vintage Class B would be welcome. Thanks!
BadPhylis is offline   Reply With Quote
Old 05-26-2020, 10:01 PM   #2
the "nickle" looks similar to material used in Europe for high traffic areas in restaurants, bars etc- it was in an RV we rented in Ireland.
It is installed with contact cement and holds up very well over time
I have not installed, but have seen installed.
install is important to work out air bubbles and etc
( the material can be pierced to let out air)
