Old 11-10-2019, 05:33 AM   #1
Default Water pump bypass winterizing valve
My 97 Pleasure Way did not have enough room to allow for a bypass valve to be installed . There was probably 4" of space and I need at least 5.5". So I installed a flex hose to the intake of the pump and brought the hose forward in front of the pump where I had more room to work . This enabled me to install the bypass valve and a water filter and made access to winterizing much easier .
gowason@rogers.com is offline   Reply With Quote
