Old 04-22-2012, 02:19 PM   #1
Default Upgrading the rear bed in a Roadtrek Adbventurous
Has anyone changed rear beds on their RT?
We visited the local dealer yesterday and looked at some of the newer model RTs. Really like that back bed in the new RS-Adventurous. Same with the 210s.
I wonder if we drove to the factory - another excuse to be on the road - whether we could get them to install one of the newer king sized beds that slide out with a push of the button?
I'm told I'd lose some "basement" space on my 2006 RS-Adventurous but I really like those newer beds.
Possible?
Anyone done such a modification?
Mike Wendland
Follow my Blog: https://roadtreking.com
A journalist takes up RVing in a Roadtrek Class B Motorhome
Roadtreking Mike is offline   Reply With Quote
Old 04-22-2012, 09:17 PM   #2
Default Re: Upgrading the rear bed in a Roadtrek Adbventurous
All the manufacturers have their versions of electric sofas that make into a bed. Roadtrek had that option in 2006. Most have bifold sofas where the back drops down and closes up to a set of ottomans and then the ottoman backrest cushions are used for infill between. No manufacturer has the same sofa. The current Roadtrek sofa is not the same as the ones that were used in 2006 models. So, to retrofit may be a fleeting wish unless Roadtrek had some left over sofas they would like to dispose of. I doubt you'll find anyone that has retrofitted. Best is to ask Roadtrek direct.
You can always correct your desires and preferences by buying a second, or third, or ... B. We are on our second Sprinter and have resolved most of our desires. You learn from experience.
Old 08-01-2012, 05:50 AM   #3
The fold down couch in my RV was not very comfortable. I bought a memory foam topper to use and it's very comfortable now. I leave the bed made up because I can't see out the back window if it's up as a couch.
soohma is offline   Reply With Quote
