Old 08-12-2015, 04:28 AM   #1
Default Travato 59G Rear access to under-bed storage?
Wondering if one of the 59G owners (esp. 2015 or 2016) could comment on the possibility of cutting an access on the rear of the under-bed cabinet to allow longer objects to be stored in that space?
I'm referring to the blank panel that's visible when the left rear door is open. Wondering if cutting a hole there would be possible, and if so, if there's enough room for a cover panel over it. The thought is to be able to load a bag that contains microphone stands and a speaker stand into there. Our speakers are likely only going to fit in the aisle under the bed, and we have to fit a few guitars, too, so I'm curious about any places where we could store items that have to be with us.
Anyone have a photo of the inside of the lower storage area below the bed? I'd sure be interested to see it.
ds10 is offline   Reply With Quote
Old 08-12-2015, 02:34 PM   #2
eric1514's Avatar
Here is a photo of the back
You could cut a hole there about 10"w x 11"h
From the side
That space is about 10"w x 11"h x 52" long.
Except for the last half.
The rear wheel well takes up more than half of that space leaving you about 5"w x 11" h x 26".
So really you have one space that is 10x11x25 and one that is 5x11x25 although it is one large space with no partition. These measurements are approximate.
Hope this helps,
Eric
"Il Travato Rosso"
2015 Travato 59g
Old 08-15-2015, 09:29 PM   #3
eric1514's Avatar
Ingrate.
Eric
"Il Travato Rosso"
2015 Travato 59g
Old 08-16-2015, 02:39 AM   #4
Thank you!
Old 08-16-2015, 03:05 AM   #5
eric1514's Avatar
Originally Posted by ds10 View Post
Thank you!
That's mo better. You're welcome.
Eric
"Il Travato Rosso"
2015 Travato 59g
Old 08-23-2015, 09:02 PM   #6
BobB's Avatar
A number of VW EVC owners add access to a rear compartment using a marine access hatch. Several companies sell them; they come in many sizes.
BobB
'99 VW EVC
Old 08-23-2015, 10:14 PM   #7
Nice. Thanks. Makes for a nice, finished look.
Old 08-23-2015, 11:20 PM   #8
BobB's Avatar
That is probably a Bomar,but there are other companies.
Bomar - Hatches - Access
Company sells retail, but check out marine suppliers like West Marine, Defender, even Amazon. Better prices, I think.
Comes in white, gray, black, etc. but note a particular size usually comes in only one of those colors. And the photo may not match the color in the description. Usually gasketed, too.
BobB
'99 VW EVC
Old 09-10-2015, 03:16 AM   #9
I'm curious on how you replace the tail light bulbs. I had to make accommodations in my build to have access to the bulbs and tail light assembly fasteners for replacement in case of damage, without major surgery to the cabinets.
[/URL]
Old 09-14-2015, 02:50 AM   #10
eric1514's Avatar
Originally Posted by mojoman View Post
I'm curious on how you replace the tail light bulbs...
That's a really good question. I'm in denial about the whole thing.
Eric
"Il Travato Rosso"
2015 Travato 59g
Old 09-14-2015, 04:06 PM   #11
eric1514's Avatar
Ok, there is an access port on the driver's side above the bed.
And on the passenger side, this long filler panel comes off.
Eric
"Il Travato Rosso"
2015 Travato 59g
