Old 07-25-2019, 12:57 AM   #1
Default Tire size
Would changing tire size to something bigger improve on wandering?
I have Cooper tire LT 215/85R 16 on my class b and having a problem with wandering. The tires seem to be narrow for the load
Any help please
Papalee is offline   Reply With Quote
Old 07-25-2019, 01:05 AM   #2
Make, model, year?
Old 07-25-2019, 01:14 AM   #3
This is a 1992 Intervec 190 with a complete front end rebuild
Old 08-01-2019, 09:23 PM   #4
That's not really enough information to give advice on tire size.
I would have the front end checked thoroughly by a competent mechanic first.
Do u have it loaded improperly ? Ie too much weight in the far rear behind axle ?
Generally lower profile tires reduce wandering if they are of the same weight capacity, but they also increase engine speed wheel bearing wear, and fuel consumption.
As a general rule I run the biggest tires with the heaviest weight rating that i can get in that size on my campers/motorhomes.
However, my guess is that if it is wandering badly, that tires aren't your problem UNLESS THEY ARE UNDERINFLATED.
so check that and weigh your camper axles front and rear separately at a truck stop to check proper distribution.
Camoman is offline   Reply With Quote
Old 08-02-2019, 05:03 PM   #5
Ford, Chevy, Dodge, or?
3/4 ton or 1 ton?
What is recommended on the sticker at the driver's door?
Old 08-03-2019, 03:13 AM   #6
Papalee,
NEED MORE INFO - as InterVec made their Class B's with Chevy, Dodge and Ford vans. They also used 3/4 ton and 1 ton chassis. Which combo do you have???
However, just by googling 1992 Chev, Dodge and Ford 1-ton tire sizes I find that the tire sizes ranged from LT 225/75 to LT245/75 sizes. Some were on 15" wheels and others on 16" wheels.
So, I'm guessing that someone prior to you put narrower tires on your RV. Also, as SteveJ suggested, look at the sticker on the driver's door that lists the "tire size" and recommended "air Pressure". That will tell you the correct tire size that your vehicle came with from the factory.
Will a larger tire help with wandering??? Maybe, but most likely No.
But I do think that your tires are probably narrower/smaller that original.
David
Now: 1998 Coachmen Starflyte FRB 21' Class B+
Formerly: 1996 Coachmen M19-RD GMC 19' Class B
TatraDog is offline   Reply With Quote
Old 08-03-2019, 06:17 PM   #7
Default Sway Bar
Check the sway bar and shocks. Look at Koni Shock web site. Keep tires as factory recommends but get good Michelin tires
David Pouliot is offline   Reply With Quote
