Old 05-24-2018, 08:43 PM   #21
As far as I’ve seen the only place you might get a response from Roadtrek is on the “Roadtreking: The Group” Facebook group and generally the response is to contact Roadtrek directly to get the answer. Sometimes there is a direct response...
That’s probably good advice if Roadtrek is set up to answer customer questions without going through a dealer.
Old 05-24-2018, 09:24 PM   #22
Mat Mobile's Avatar
It's true that in a forum such as this one, answers can get misunderstood, applied in the wrong context, given without enough information, etc.
Having the customer contact the factory directly really is the best way to provide the correct answer. Even if it seems a little "old school".
I can't imagine, for example, Honda keeping track of all the Civic forums!
Old 06-16-2020, 10:15 PM   #23
Default After 5 years, new Supersprings BUMP STOPS
I run around 9500 lbs.
Was in Santa Barbara & thought its time to add the new Bump Stops - even though the others were working, the new ones even out the load instantly
