Old 03-28-2024, 06:34 PM   #61
Originally Posted by Bangorbob View Post
So IF I were to install electric fans, would they be push or pull?
It depends on where you mount them and which way the fan is turning and the cut of the fan blade.
Old 03-28-2024, 07:12 PM   #62
The would push from in front of the radiator and AC condenser.
Old 03-29-2024, 12:48 AM   #63
I really didn't ask the question correctly. Which is better, push or pull, or is there any difference?
2005 Roadtrek 05C210v
2020 Can Am Spyder RT Limited
Bangorbob is offline   Reply With Quote
Old 03-29-2024, 01:11 AM   #64
The ability to have a place to put them usually determines the location and with the Chevies in front of the radiator is the only place they will fit unless you ditch the mechanical fan, shroud, etc and install a huge sized electric set of fans. You also have to supply the power and control of them so not a small job at all. Almost all auxiliary fans are in front of the fan so are pushers. Fans usually generate better pressure pushing, but you can't effectively use shrouds, so pullers have an advantage there. In front is pretty easy on the Chevies, but oil coolers can get in the way.
