Old 11-08-2016, 10:48 PM   #1
Default Stereo upgrade Promaster
Pulled out the cheap stereo and put in a nice one since the cheap one couldn't handle 4 ohm speakers. A 10" powered marine subwoofer fits perfect under the seats and you can get some hefty 6x9"s in the overhead bin area. Put a couple of some polk 4" speakers in the back. Sounds great. Ordered some good 6.5" speakers for the doors. The factory speakers look like they cost $3. Lots of trim work left in the overhead areas to do so it looks like another trip for some more mahogany.
Old 11-09-2016, 02:40 AM   #2
Looking good!
Old 11-09-2016, 06:59 AM   #3
Hein's Avatar
We have CNC machined expanded PVC adapters that you can use for the door speakers. They position your new speaker at a slight upward angled like the OEM speakers.
link: Promaster Speaker Adapters for 6.5in speakers | eBay
Hein is offline   Reply With Quote
Old 11-09-2016, 06:24 PM   #4
FYI, the type of multi-connector I used, that long plastic one in the photo, I would not use again. The brass inserts strip easy and are a pain to replace, in place. I try to insure everything I instal can be removed without cutting wires. Most everything else I used Screw Terminal Strips which are stronger .
