Old 06-15-2018, 03:17 AM   #1
bigfelipe's Avatar
Default SS Agile shower... Question about wall material?
Anyone know what the glossy white plastic used for RV shower walls is made of? It's a thin plastic over paneling, not fiberglass. I need to cover a hole where I removed a sink and would like a similar material to match it.
bigfelipe is offline   Reply With Quote
Old 06-29-2018, 04:59 PM   #2
Default Roadtrek Agile SS shower
I am not sure. I just removed my sink also. I did find a white, cutting board at Target (Farberware Essential 3 Piece Cutting board set) with the largest board at 11"x16" that fits over the hole perfectly however, I am going to a glass cutter who also does plastic and ask what it would cost to cut something to cover the hole. BTW, I found a metal kick-plate for a door at Home Depot that is 8"x16" that covers the back side of the hole perfectly.
danmc1963 is offline   Reply With Quote
Old 06-29-2018, 06:39 PM   #3
Hatteras Jim's Avatar
It could be ABS? You can get it in very thin sheets and glue that onto a luan base. A plastics supplier may help. There's a good one in the Raleigh Area that handles all kinds of plastics from thick to thin. Piedmont Plastics is their name. Been there and its quite an operation.
Old 06-29-2018, 09:46 PM   #4
bigfelipe's Avatar
Thanks guys. I used a piece of white acrylic on the inside and luan on the outside. Doesn't look bad at all and cleaned up the space nicely...
