Old 07-02-2016, 04:42 PM   #1
cargovanconversion's Avatar
Default Spray Foam Floor Insulation
I've been working on the sub-floor and removed the tie-downs, insulated the wheel wells, created plywood templates and cut & glued the strips of Poly-Iso to the floor. Now I filled in the voids between the insulation panels with a spray foam application.
Although it is a closed-cell, waterproof foam, after cutting off the excess, what remains is susceptible to moisture, but still adds insulation and some structural cohesion to the floor.
The mod can be viewed here: Mod: Insulated Floor – Spray Foam Application
Van Williams
CargoVanConversion.com
cargovanconversion is offline   Reply With Quote
