Old 10-08-2014, 05:47 PM   #1
Default Sliding Door Screen
Anyone found a good source for an after market bug screen for the Sprinter sliding door? I want one that slides closed and open and not have to roll it up. I have a 2010 Pleasure Way Ascent (2008 "Dodge" Sprinter).
dmichael is offline   Reply With Quote
Old 10-08-2014, 07:22 PM   #2
Default Re: Sliding Door Screen
There are two types being used. One is an accordion type snap open kind originally installed by Great West Van starting back in 2008. Another is the roll out screen similar to what you see on combination screen doors now. Either way they fit in aluminum frames and then the frame has to fit against built out, usually wood, trim stops matching the cabinetry to accept it. Because the new Sprinters have the high doors on a curvilinear surface it is not an easy thing to do without the custom stops. Roadtrek, for whatever reason, has been slow to join the group so I don't know if they have anything in the works. Advanced RV has done custom work to install their screen on other manufacturer's Bs. The ones I know and have seen have been on Winnebago ERAs.
