Old 07-11-2017, 10:24 PM   #1
Default Sliding Door Bug Screen
Hi:
Anyone know how to make an inexpensive anti bug screen for the Promaster?
Thanks!
Old 07-11-2017, 11:42 PM   #2
I will be watching this thread.
Alex.sym is offline   Reply With Quote
Old 07-12-2017, 02:54 AM   #3
line the edges or the opening with self adhesive hook velcro
get an as-seen-on-tv walk through screen kit
push it onto the velcro- the screen itself will stick- it is not real screen it is more like a paper fiber
trim bottom and sizes to fit
cost about $15
mike
Old 07-12-2017, 02:53 PM   #4
I recently finished an awning screen which is a bit different than a fitted sliding door screen, a bit more ambitious of a project (blog post with material sourcing here).
I plan to also do a separate fitted slider screen for those times when I need the ventilation from the sliding door, but I'm not staying put long enough to bother putting up the entire awning assembly. But I haven't gotten to that project yet.
If you go the route of DIY, you might want to check out the noseeum fabric that I reference in that blog post above. It's cheap and quite good quality, and packs down amazingly small because the gauge is so fine. I would never want to stuff a conventional heavy mosquito screen into any Class B.
I also used this noseeum fabric to make a fitted rear door screen, which is held on using neodymium magnets (blog post here). The issue I've heard with Velcro attachments is that, if they get wet, they tend to stay wet, and hold that wetness in undesirable areas - right on the steel door frame.
We have a Yeti cooler on our hitch carrier which blocks the opening of the driver's side door much of the time, so this particular rear screen was constructed to be only one door wide:
Old 07-12-2017, 03:59 PM   #5
+1
Very nice
Old 07-13-2017, 09:03 PM   #6
Thanks very nice.
I found this solution on another site. Here is the link. Easy sliding door bug screen - Ram Promaster Forum
Old 07-13-2017, 10:00 PM   #7
You also might get some ideas from Pleasureway.com and their video on what's new. In the video the sliding door bug screen for their Promaster is demonstrated. It is 5:11 minutes in
http://pleasureway.com/
techfan is offline   Reply With Quote
Old 07-13-2017, 10:37 PM   #8
Hi:
Can you tell me where you purchased the magnets? What kind are they? Brand and size, special features?
How far did you sew them apart so insects did not sneak in. I really like the DIY approach. Way less expensive! Thanks a bunch for any and all assistance.
Old 08-07-2017, 10:41 PM   #9
DIY adaptation of a household "Magic Screen" for a Promaster... toward the end of the page...
https://vancave.wordpress.com/cargo-...miscellaneous/
Best,
Phranc
Ram Promaster 3500 ext Gasser DIY Camper Conversion... Q
Phranc is offline   Reply With Quote
