Old 10-28-2006, 09:32 PM   #1
Default Roadtrek Skylight Window Covers by Ron
Here's a link to Ron's Roadtrek Skylight Window Covers
http://www.allcapemusic.org/rtwindows/rtwindows.html
Great Job!
Old 01-05-2011, 09:42 PM   #2
Default Re: Roadtrek Skylight Window Covers by Ron
A forum member pointed out that the above link no longer works.
It looks like it was removed from that site. I did find the text and a few photos.
Materials:
A- 1 - 1/8"x2'x4' Hardboard purchased at Home Depot-SCU: 718793318126 - $2.39
B- 6 - 2 1/2" Suction Cups with Hooks attached.
C- 6 - #6- 1/2" Sheet Metal Screws
D- Spray Can Primer Paint
E- Spray Can White Paint
F- Spray Can Black Paint
G- 9/64" Drill
A- Used Brown Paper Bags, Unglued/Opened up made a large sheet for Temp Plate
B- Placed a Sheet up against each window, taped sheet onto ceiling/material
C- Held on Sheet/Temp Plate, traced around framing that has screws attached
D- Used Carbon Paper, traced outline on Sheet/Temp Plate onto Hardboard
E- With Saber Saw cut the traced outline
F- With Table Sander, sanded each Cover edge
Left & Right Windows:
A- Measured 2 1/2 inches from top, drew a line side to side
B- Measured 3 inches from both side edges
C- Measured 2 1/2 inches from bottom, drew a line side to side
D- Measured approximately 7 1/2 inches from side, (middle of bottom)
E- With 9/64" drill, drilled hole for screws to screw onto Suction Cups
Middle Window:
A- Measured approximately 2 1/2 inches from top, drew a line side to side
B- Measured approximately 7 inches from side for center
C- Measured approximately 2 1/2 inches from bottom drew a line side to side
D- Measured approximately 3 inches from both side edges
Old 06-22-2016, 03:03 PM   #3
Send a message via AIM to sewright33 Send a message via MSN to sewright33 Send a message via Yahoo to sewright33
Wow never think I could not think of anything to use and it was sitting right in my face --
The phone Holder is stuck to my window with suction cups
Thanks
sewright33 is offline   Reply With Quote
Old 06-22-2016, 08:54 PM   #4
peppster66's Avatar
That is very nicely done, a new project for me to try,,, thanks,,,,
peppster66 is offline   Reply With Quote
