Old 09-17-2017, 09:24 PM   #1
Default Removing Calk from Outside Van
My 1997 RV came complete with calking between the cab and body to cover a crack. It has been fine until now. Today I noticed it was black (probably mold) and sticky.
What can I use to remove it without damaging the finish of the van so that I can put new calking on.
I've seen mineral spirits, vinegar, commercial calking remover, hair dryer and knife.
soohma is offline   Reply With Quote
Old 09-18-2017, 03:53 AM   #2
wincrasher's Avatar
Gasoline will clean it up.
2019 Winnebago Travato GL
Old 09-18-2017, 05:04 AM   #3
Razor blade scraper
Old 09-18-2017, 11:09 AM   #4
The tool in this photo works great to remove caulk.
It's next to a popsicle stick to give an idea of the size.
I've removed a lot of caulk over the years and those little plastic or nylon tools work the best by far. A key to success is to work on a 1/4" or 1/2" at a time and it comes off fairly cleanly. If you try to brute force it the caulk seems to fight back and adhere stronger and or break. If you work just a little bit at a time it releases with less effort.
I got the tools at an RV place where I purchased new caulking.
Old 09-19-2017, 02:45 AM   #5
Default Removing old calking
Thanks for all the suggestions. I'll look for the plastic tool, but maybe try a bit of gasoline also. I'm afraid if I use a razor I'll regret it!
Old 10-19-2017, 12:25 AM   #6
they do make plastic razor blades, used them to take excess caulk off aluminum siding.
71choptop is offline   Reply With Quote
Old 10-19-2017, 01:11 AM   #7
Never heard of such a thing. Thank you for the suggestion.
calking, method, removal
