Old 07-19-2016, 08:19 PM   #1
cargovanconversion's Avatar
Arrow Plywood Sub-Floor
It was time for the plywood to be added to the Poly-Iso insulation panels on the floor of the cargo van. I use the paper templates that I made previously to remove the cut-outs from the sheets of plywood and add dadoes to form an interlocking system.
Although I ended up sealing the plywood at a later stage, this is the time to get your Shellac, varnish or polyurethane and a couple of brushes and protect the plywood against moisture.
As always, I have detailed every step on the Project’s Page, and added lots of pictures and videos.
Comments are welcome!
Van Williams
Save
CargoVanConversion.com
cargovanconversion is offline   Reply With Quote
Old 07-19-2016, 08:53 PM   #2
Pleasure-way use 3/4" plywood for their floors.
I know they overbuild their stuff.
I am sure 15/32 is more than adequate.
Do you have any afterthoughts?
Old 07-19-2016, 09:28 PM   #3
I already mentioned that on the website.
I, too prefer 3/4 inch ply, mainly because all the cabinets and appliances will be attached to it and it needs a solid foundation. But then there are the issues: more expensive, heavier (important!) and for me especially the thickness.
I have a 2016 Ford Transit medium roof with approx. 69 inches available between the top of the floor ribs and the bottom of the roof cross members.
Being 5'-7", that leaves very little room for floor and ceiling material. Put in very little insulation material, only between the floor ribs, then the 1/2 inch ply, with an additional 1/2 inch for the finish floor. Take another 1/4 inch min. for the ceiling, that would leave me with about 1/2 inch between me and hitting my head.
The 15/32 should be sufficient and every year I get to be a little bit shorter as well.
If you have more standing height in the living area of the van, I would suggest an extra 1/2 to 1 inch of Poly-Iso floor insulation and with enough GVWR the 3/4 inch plywood sub-floor.
Like many things in a van conversion, compromises must be made.
Van Williams
Old 07-19-2016, 10:43 PM   #4
Thanks for the reply.
I forgotten you need another 1/2 inch for the finish floor.
