Another cross-post here, because there are many people on this forum with engineering skills.
To make an 8-year-long story short, I carry frozen food into the backcountry using the method shown below (original thread
here). I freeze vacuum-packed food pouches into monolithic ice blocks formed in a mold that we built to conform to our Yeti cooler which rides on our Class B’s rear hitch carrier.
This is one of the best off-grid mods I have ever developed, as it revolutionized our food logistics. We eat fabulously well in the wilderness, miles from any food source.
I am now aspiring to improve this method even further. I think I can extend the life of the ice blocks if I can find a way to lower their temperature while off-grid, without needing machinery or electricity.
For this idea to work, I cannot simply embed (for instance) a segment of plain copper pipe into the ice blocks. The object must function like a heat exchanger, so it needs to have fins, or plates, or some structure to that effect.
Also, whatever its configuration, the channel(s) into which the nitrogen is poured cannot be too narrow, because of the surface-area-to-volume issue and the boil-off that will occur (I worked with LN2 in a laboratory setting for years, so I know how it behaves). I have to be able to get the LN2 in there such that it sits long enough to suck heat out of the ice blocks before dissipating.
Trouble is, I cannot find heat exchanger material similar to that shown. The only sources I've identified are Asian mass market wholesalers such as Alibaba and the like, and as a consumer, I can't procure from sellers of that type.
But maybe I am not thinking widely enough. Ideally, the object identified to serve this purpose will be aluminum, but it doesn't necessarily need to look exactly like the examples shown below.
Does anyone have any ideas on what I might procure for this purpose? Thanks.
