Old 07-26-2015, 03:50 PM   #1
wincrasher's Avatar
Default Need panel wiring info
This is the back of my distribution panel.
What I think I'm looking at is the yellow wires on the left are positive 12v and the white wires in the block on the right is negative 12v. There are other sealed connections further right that I believe are the 110v connections.
I put a continuity meter on the ground on the converter, and touched the block with the white wires and it illuminated. So I'm fairly certain that is negative.
Correct?
2019 Winnebago Travato GL
Old 07-26-2015, 04:00 PM   #2
eric1514's Avatar
I would use a volt meter to test positive or negative, not a continuity light. But I think you're right, anyways,
"Il Travato Rosso"
2015 Travato 59g
Old 07-26-2015, 04:01 PM   #3
Yep. Ground is a bus. The yellow wires are going to individual fuses that feed the +12 to the various circuits. There should also be a large "+12VDC In" lug somewhere that feeds the +12 to a bus that feeds the fuses.
Old 07-26-2015, 04:06 PM   #4
wincrasher's Avatar
Thanks. I'm wanting to add a 12v/voltmeter/usb panel to the dinette seat.
Looks like I have an open slot, so I'm going to connect it there and add a 20amp fuse.
Old 07-26-2015, 06:18 PM   #5
wincrasher's Avatar
Looks like I got it. No fires yet.
Wincrasher's Travels: Adding 12 volt, USB and Voltmeter Outlet.
