Old 02-25-2016, 11:41 PM   #81
Default Finally done with power center
Designed to be completely and easily serviceable in place or center removed completely. Front panel lifts up for access, quite a wiring feat but worth it.Batteries to be installed when mounted in place, bolted from bottom under floor. Magnum 2800 pure sine inverter mounted on battery lid, slides in after batteries installed. Has battery temp and voltage alarms, cabinet lights, auto vent fan with extra twin booster fans, BMS. Main battery cutout switch and main/aux battery switch. Most everything marine grade, stainless. I have more controls to install but there isn't room.
http://s1276.photobucket.com/user/mc.../Mojovan/story
Old 03-28-2016, 03:26 AM   #82
Default Passenger countertop
Just about done with the passenger side countertop. Induction cooktop, instant hot water dispenser, pot filler, flip up extension and a deep sink. It a little over 6' long with the extension. GFI plug and switch (all appliances will have a switch to curtail parasitic loss). I have a vent fan for the induction cooktop mounts on the back.
Old 03-28-2016, 12:05 PM   #83
I've just been catching up viewing all of your photos:
mcgiotes's Recent Uploads | Photobucket
The whole project is looking great. Unique. Great use of space. Love the counter space. There's nothing like this available from the market place.
Old 03-28-2016, 02:27 PM   #84
Thanks, We ended up with 25" of aisle width @ the counter and 28" @ the floor. Utilizing the recesses in the walls and the extra width of the Promaster allowed me to maximize space. Aisle width and counter space was a priority. We are able to walk by each other in the aisle and it makes the unit feel more open, less confined, especially in a van less than 20' long.
Old 04-25-2016, 08:55 PM   #85
Hi Mojovan
What kind of screen door did you use? brand?
Thanks in advance!
Rafael
Goldenraf is offline   Reply With Quote
Old 04-25-2016, 09:38 PM   #86
Only source I know of is the distributor at:
drodabaugh@hotmail.com
Old 05-13-2016, 02:15 PM   #87
Default Air bags installed
I noticed my generator was hanging lower to the ground from the weight of my build. It is 8 1/2", still above the bottom of the axle though I haven't loaded the unit with gear yet so I ordered a set of Boss air bags. Very high quality bags and are quite easy to install, about 1hr. I raised 1" and leveled the back of the van with about 20/25lbs of air. It drives better on the highway, less minor correction and quicker steering response, as it was prior to some of the weight gain. I also have an Helwig rear sway bar installed which is larger than the factory unit.
I would highly recommend these bags for any Promaster class b, especially the generator installed units since they hang so low. I was able to install my Onan 2800 with about 2 1/2" more ground clearance by cutting out the spare tire mounting crossmember and fabricating my own mounts.
Old 05-13-2016, 06:47 PM   #88
Have you had it on the scales yet to see where you are at on load capacity?
Old 05-13-2016, 07:32 PM   #89
My van is rated at 4010lbs load capacity I'm guessing 1600lbs in my build when done and 1000lbs for passengers,water fuel gear etc.... I'll weigh it when finished.
Old 05-15-2016, 12:24 AM   #90
Default Inverter load test Magnum2800
I pulled 1440 watts on low 1560 on high for the coleman Mach8 13500 unit. I turned on the instant hot water heater (750 watts) and ran the microwave at 50%. All at once. No problem.
I calculated I can safely run my ac for over 6hrs just on the batteries (900AH lithium) in no sun, 7 hrs or more with sun. 400 watts solar panels MPPT, controller averaging 200watts.
Old 05-15-2016, 04:24 AM   #91
Love it. Must feel good after all that work.
Old 05-15-2016, 12:55 PM   #92
Nicely done That's the type of system performance these advanced setups should deliver.
Old 05-17-2016, 08:02 PM   #93
Default More progress
Mojovan Story by mcgiotes | Photobucket
Dinette works great, can set up where one can still lay down and the other can sit. Reading lights work great .
Old 05-29-2016, 01:17 AM   #94
Default Custom Sunscreen
Wife finished the sunscreen, marine grade 5% light in. Also stainless generator exhaust, air bags and brush guard. Wife also made internal cab window shades made of reflectex/thinsulate/black material. Reversible so either white or black showing inside or out.
Old 07-11-2016, 04:26 AM   #95
Wow awesome build. Thank you for the details and photos. Very fun to read and the van looks great.
One question, why a standard generator vs a second alternator? We are investigating different brands and models of vans with different options. Underhood generators seem the rage so interested with a DIY project why you chose your setup.
Old 07-11-2016, 02:34 PM   #96
The alternator wasn't available when I started the conversion. After using the unit I realize I may not need the generator, the 120 amp battery to battery charger may be enough. I also wanted a system that can operate completely independent of the van's engine/electrical system for warrenttee purposes. The Onan generator does operate more efficiently wth regard to fuel consumption but does use up space and weighs more. With super efficient insulation, all led lighting, an efficient DC compressor fridge, the demand for power is significantly reduced. If I had to do it over I would eliminate the generator and add more lithium capacity and a high amp shore power charger.
Old 07-14-2016, 10:14 PM   #97
Default Mach 8 noise reduction kit results
Just installed the noise reduction kit, quite a nice reduction in the noise the AC makes. Worth the modest price for those with a Mach8 and want to quiet it down to a pleasant hum. I added some acoustic foam while I was up there.
Mach 8 noise reduction partial kit
Old 10-10-2016, 10:52 PM   #98
Default TV and fan
Rather than a cabinet we installed a fan and 22" DVD/TV in the bed area. I was difficult to view the 15" TV installed in the forward section. We determined have plenty of storage so opted for more open space. The switch is spring loaded so I can turn off the fan with my foot while in bed, also two more 12v outlets and a light.
Old 10-11-2016, 12:49 PM   #99
............. I can turn off the fan with my foot while in bed...........
That's convenient
Lots of space remaining also if any new device needs to be mounted.
Old 10-29-2016, 01:48 AM   #100
A/C and sideways Maxxair install. Used plastic for rib spacers and a plastic base to distribute load and seal better. They are move as far back as I could and Maxxair sideways to fit 4 solar panels. Tight fit but it will fit.
http://s1276.photobucket.com/user/mcgio ... t=3&page=1
What do you think of a solution like the ecotrek where they mount a second alternator on the van's engine? Saves weight. It's quiet. Doesn't use a lot of space. May use a little more gas but not a huge difference. I'm curious because I was sold on this solution. Sounds pretty good on the surface at least. The fit RV website used a similar solution.
Cannuck is offline   Reply With Quote
