Old 08-07-2015, 03:48 AM   #61
Why did you remove the stripper poles?
Old 08-18-2015, 08:56 PM   #62
I little more progress, fitting the dry toilet, managed to get it pretty tight to the wall.
Mojovan Story by mcgiotes | Photobucket
Old 10-07-2015, 11:15 PM   #63
Default Few more things done
Aux battery mounted, to be used when main lithium unit is not needed, bathroom walls in. Calculated interior of bathroom by sitting on toilet, measuring how far my knees and feet protrude for depth, and for width, included elbow and arm swing needed for the "paper work". Lower raised area will contain Aux battery,heater, sterling battery to battery charger, aux battery controller, battery cutout switch, trickle charger and what ever other electrical stuff I can fit into the area.
Old 10-08-2015, 04:21 PM   #64
Lot's of progress - I hadn't checked recently.
This link might show the newer photos: mcgiotes's Recent Uploads | Photobucket
Old 10-12-2015, 07:10 AM   #65
Many people think they need a door to the restroom.Consider a drape instead.Lighter and flexible.
Old 10-12-2015, 02:11 PM   #66
Yes, that was my first thought until the wife demanded a door.
Old 10-23-2015, 10:59 PM   #67
Little more headway, built a cabinet around the fridge 7 CF marine unit 12v and 110 with the ventilation ducted over the top. It is removable as a unit so any problems down the road I can remove the whole cabinet and fridge. Front step area almost done and will house allot of electrical stuff and the heater.
Old 10-25-2015, 09:01 PM   #68
cargovanconversion's Avatar
Nice looking fridge!
Van Williams
CargoVanConversion.com
cargovanconversion is offline   Reply With Quote
Old 11-12-2015, 09:47 PM   #69
Default Bamboo countertop
and other progress
Old 11-26-2015, 03:05 PM   #70
Yes. A very nice fridge. Can you tell us where you bought it? I think you mentioned getting it in Florida.
PhillyGeorge is offline   Reply With Quote
Old 11-26-2015, 03:16 PM   #71
wincrasher's Avatar
Wow, it's really coming together. Really like the scheme you are going with - dark cabinets, light/white flooring and stainless appliances. Really pops!
That fridge is tremendous. Looks to be this one? http://www.defender.com/product.jsp?...6235&id=922260
2019 Winnebago Travato GL
Old 11-27-2015, 09:05 PM   #72
Yup, that's the one, that's why I installed a dedicated surge protector to it. Its the most I every paid for a fridge in my house! It uses very little power to operate and very quiet.
Old 12-28-2015, 08:26 PM   #73
Default A bit more done
Cabinets, TV/DVD on hinge, inverter microwave, counter extension.
Old 12-28-2015, 11:00 PM   #74
Solid woodwork! Where did you get these cabinet locks?
Van Williams
Old 12-28-2015, 11:48 PM   #75
Van Williams
Southco M1 or similar. Sportsmobile uses these on almost all of their builds.
M1 - Flush Pull Latches - Southco
Old 12-29-2015, 12:00 AM   #76
Amazon had them for a while.
Old 12-29-2015, 12:16 AM   #77
It's time for me to start thinking about latches and other hardware. These seem quite solid and look attractive.
Van Williams
Old 01-04-2016, 12:41 AM   #78
Default One more cabinet
Weather gauges,heater control, battery charge controller, led lights. First attempt at caning/wicker.
Old 02-02-2016, 10:23 PM   #79
Default Started power section
Started on the lithium battery pack, inverter section. Its designed to so I can service anything in place. A plate slides over the battery section and the Magnum 2812 bolts to the plate. Most of the controls and power panel will be mounted to the door/access and hinged for ease of access. (20) 180amp lithium cells, 400amp fuse, inverter/charger controller shunt, Contactor, dual pole battery switch. The buss bars were made with my VCM, "vice,cresent wrench & mallet"
The pack will have 4 ways of charging, solar,alternator,shore or generator.
Old 02-13-2016, 05:13 PM   #80
Default Power center
Almost done, it will be easy to access for service. the entire center will weigh in at about 350lbs including the batteries and the really heavy inverter.
