Old 05-15-2018, 06:06 AM   #21
i just received the owners manual and it's invaluable. i am used to the gravity pump, which i love. i really dislike this set-up. i am looking into having it changed, if possible. i also am not used to such a different set-up. my last rv was a rialta, and the first, the love of my life, was a 17ft leisure way, both using the gravity system. many thanks for your reply, i love this forum.
joannehafner is offline   Reply With Quote
Old 05-15-2018, 06:41 AM   #22
The macerator on your 190 was included as standard equipment, not a profit oriented option. You might well be OK without it but on the Chevy the dump hose height seems fairly low to the ground and with just gravity feed there may be dumping incidents where you just don't have sufficient hose pitch to drain well. With the positive pressure macerator, that ceases to be a problem. Some folks on the forum have reconfigured their macerator setup so that it normally remains on line but can be conveniently bypassed. IMO, that's a better approach than eliminating the macerator in its entirety.
BTW, one thing easy to forget on your coach is that if you discharge the batteries down too much, when plugging into shoreside, the battery charger will not start up unless you run the engine for a brief period to kick start the charger into liftoff. It's no big deal but without knowing that, things can get confusing.
The manual for your year 190 is surprisingly comprehensive, much more so than the manual for our 2017 210PC.
Old 05-15-2018, 06:49 AM   #23
that's a great point about being plugged in too long and then trying to use the macerator. i am just so relieved that this forum exists. i am a complete deer in the headlights with this roadtrek. i am used to old fashioned simplicity with my rigs. if i had known how complicated and difficult it was to pull out and re-stuff the hose into it's compartment i would have re-considered this set-up.
Old 06-16-2021, 05:47 AM   #24
Booster's photo in #18 illustrates the battery switch which must be on for any 12 volt appliances to operate, the macerator included. FYI, the macerator is fuse protected with a 20 amp fuse in the DC fuse panel.
Dry testing for macerator functon should be brief. They don't like being run dry for a long period.
Do you have the owner's manual for this coach?
Hello,
Do you know where the fuse for the macerator is in a 2017 RT Simplicity SRT? I checked each individual fuse in two locations, one under the steering wheel on the left inside and the other location, under the hood. Macerator stopped working and not entirely sure how to proceed. Any info will surely help. Thanks.
denialnog is offline   Reply With Quote
