Old 01-13-2019, 12:11 AM   #1
TC8
Default Little outside light refit Roadtrek 05
Ever wonder what to do with that Itty bitty light on the passenger side of the Roadtrek. This is what I came up with.
Rather than remove the housing and buy another one. I took the incandescent light bulb and broke the glass bulb. I made sure I did not damage the two post that held the filament. Using a meter I determined which post was connected to the negative brass case and the positive point at the tip of the base. Once I did that I soldered the wires that corresponded to the wires on an LED strip lights. The old cover blew off recently so I had to make a new one and I used scrap plastic. I drilled a hole at the bottom of the new cover. I then put silicone sealant to seal the hole. I put dielectric grease on the fittings and installed the bulb base back into the socket and Wala new lights.
File Type: jpg 4052A96C-117B-475E-A9F3-CE21B2330248.jpg (148.5 KB, 9 views)
File Type: jpg 5476F5BC-4985-4926-8B7A-F6BC804B86FF.jpg (177.2 KB, 10 views)
File Type: jpg 73C8D984-DF46-4732-922F-508599944328.jpg (84.2 KB, 18 views)
TC8 is offline   Reply With Quote
