Old 09-12-2009, 03:43 AM   #1
g1g
Default how many watts here
I have the opportunity to get a used solar panel about 18-24 inches by about 4 feet long. Any idea on how many watts it produces?
Old 09-12-2009, 04:16 AM   #2
Default Re: how many watts here
40 to 80 watts I'd say.
Size is not the only factor.
Less efficient cells = larger panel.
More efficient cells = smaller panel
My 75 watt panel is just about the same size as you describe.
Copied from here:
viewtopic.php?f=12&t=712
There are three types of Solar Cells on the market.
Amorphous or Dual Junction Solar Glass - Cheapest but only 7% energy efficiency and 5 years service life. It is big and heavy. If the seller didn't specify, it is the Amorphorus. It is black solid sheet in appearance. It is about half the price per watt compare to Mono-Crystalline. Most of the solar panels on Ebay are of this type.
Poly-Crystalline - 25 plus years service life under direct sunlight and 13% efficiency. It is blue color circular or semi-circular silicon wafer form in appearance.
Mono-Crystalline - 25 plus years service life and up to 20% efficiency. This is the same type use in solar car racing. This type of solar cells is now in worldwide shortage because only a few companies can manufacture this type solar cell. The raw material which is a special kind of silicon sand ore is also in great shortage. It is in black color circular or semi-circular silicon wafer form in appearance
Old 09-13-2009, 01:22 AM   #3
My Carmanah panels are rated at 95 watts at 17.5 volts max output. 'They are monolithic crystal construction. They are about 22 by 41 inches in size.
VernM
GMC Conversion Van and WellsCargo traiiler
https://www.classbforum.com/images/1994%20GMC.jpg
VernM is offline   Reply With Quote
