Wheel & tire update.
I have ordered a set of Method 310 wheels and larger BFG tires for the 210.
While the 275/75R-17 tires are good, when the 210 is at it's maximum weight the tires will have a good weight safety margin (how much weight they can handle) but I wanted to have a larger margin that the bigger tires can provide. The taller tires will also increase the lift a small amount.
The 17's are rated at 3,195 lbs per tire and I have ordered a set of larger 18 inch tires that will be rated at 3,640 lbs per tire. This will increase the safety margin (think of it as the tires not working as hard) especially when a motorcycle is on the rear carrier.
The wheels, Method MR310, bronze finish, 18 X 9, 18mm of offset, rated for 3,600 lbs of load -
I will be trying tires on, starting with the larger BF Goodrich T/A KO2 275/70/18... this tire is 1 in taller than the current 275/70-17 KO2. This tire is rated at 3,640 lbs each.
If they are too large then we will be using a 265/70-18 KO2 which is .4 inches taller than the current 17. This tire is rated at 3,525 lbs each.
Here is a pic of an Express van with 5 inches of lift, Method 310 wheels -
I'll be installing these next week... stay tuned!
