Old 09-07-2009, 03:07 AM   #1
Default Fuel pump for microquiet 2800 generator
I have a Microquiet 2800 mounted in a roadtrek. The fuel pump is dead and the generator runs fine with my rigged up gravity feed. Does anyone have the Onan part number for the pump for gen. spec LVF. Alternately does anyone know what PSI this genset will handle. The owners manual says 1 to 1.5 Max PSI.
There are lots of pumps for a reasonable price on eBay, but the lowest PSI is rated 1 to 3. I am going to bypass the old pump and reroute the feed so I would like to hear about anyones experiance. I am afrain that 3 PSI might be enought to overcome the float valve and cause a flooding condition. Thanks, Jack
K1smm is offline   Reply With Quote
Old 09-07-2009, 03:51 AM   #2
Default Re: Fuel pump for microquiet 2800 generator
Don't know if this will help but the generator in our 2006 RT is a KV and the parts manual lists the fuel pump part # 149-2331-03.
If you go to the onan website it will tell you the parts manual number. If it is # 981-0238G that is what I have.
FLSTFI is offline   Reply With Quote
Old 09-09-2009, 01:10 AM   #3
Yes, that certainly does help. I couldn't even find the part number on the Onan site. Thank you for your help.
Jack
