Old 03-13-2022, 10:52 PM   #21
jls
thank you
jls is offline   Reply With Quote
Old 08-29-2022, 05:32 PM   #22
Originally Posted by jls View Post
It turns out that the gasket is in place so that's not the issue. but i can confirm that there is about 3/4" of movement possible on the far corner from where the hinge is located when the fan is completely closed tight. This is what is able to vibrate with the wind and traveling at highway speeds.
I'm really surprised to hear that no one else has this issue.
I'm not sure there is any room to add the additional cover as suggested since there are solar panels on either side of the fan mounting. Unless the the cover fits, right on top of the white plastic fan mount area.
I too have an annoying vibration in the fan when traveling, and I agree the arm to raise and lower the lid is sloppy and flimsy. I have had several RV’s previously and not experienced this problem. My Rv is a recent purchase and I will be attempting to resolve this issue. Thanks for being the subject to attention…
Alan 4198 is offline   Reply With Quote
Old 08-29-2022, 08:21 PM   #23
Welcome to the Forums
I had that issue, I added a cover to vent fan so that i can have it open in rain while driving or parked.
That took care of the floppy lid
It looks like a trash can on the roof, it required me to re-engineer the antenna to clear it and it increased my height
but it's a good add
Old 09-02-2022, 04:29 PM   #24
jls
thanks mike. i've been getting by with some foam to dampen the vibration but would like to do better... was the cover you added this one?
https://www.amazon.com/Fan-Tastic-Ve...dp/B007HGF398/
Old 09-02-2022, 05:45 PM   #25
It is a Fantastic Fan ultra breeze.
I spent about $38 7 years ago.
I has remained in great shape in the arizona sun and ozone
mounting is 4 studs are attached to the vent frame, the cover goes over the top, then washers over the studs and spring clips through holes in the studs
I did mine at the same time as i was resealing penetrations in the roof and had removed the vent so that I could stand on a stool and work on the roof through that hole. I then resealed/reinstalled the vent and put the cover on then
( this has been updated as I confirmed the make/model/cost)
